Y282 Posted April 29, 2016 Share Posted April 29, 2016 Welding class last night, built up the dogbone ready for redrilling. Before and after... Link to comment Share on other sites More sharing options...
Y282 Posted May 2, 2016 Share Posted May 2, 2016 Reprofiled inner frame webbing and filed down top eyelet width on shock... Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted May 2, 2016 Member Contributer Share Posted May 2, 2016 I love the english language (I'm not a native speaker....) Re profiling = took a lump out :-) Keep up the good work! Link to comment Share on other sites More sharing options...
Alhazred Posted May 2, 2016 Share Posted May 2, 2016 Some guy sold me an almost mint Fox shock for $25 to do this,the shaft did look pitted in the pics but it's actually fine. I was considering this ZX swap before I found the Fox. What do you guys think Fox or ZX shock? Link to comment Share on other sites More sharing options...
Y282 Posted May 4, 2016 Share Posted May 4, 2016 Apologies for the hijack, but the more I'm working on it, the more stuff is needing to come apart. It's been neglected a fair bit prior to me getting it. Had to cut the locking nut off the rear hub. Everything needs a proper strip down and clean. Back brake had one seized piston too. Anyway, pics if anyone's interested... Link to comment Share on other sites More sharing options...
Member Contributer JZH Posted May 4, 2016 Member Contributer Share Posted May 4, 2016 2 hours ago, Y282 said: Apologies for the hijack, but the more I'm working on it, the more stuff is needing to come apart. It's been neglected a fair bit prior to me getting it. Had to cut the locking nut off the rear hub. Everything needs a proper strip down and clean. Back brake had one seized piston too. Anyway, pics if anyone's interested... LOL, are you married? I sure wouldn't be if I tried to use the kitchen sink as a parts washer... Ciao, Link to comment Share on other sites More sharing options...
Y282 Posted May 4, 2016 Share Posted May 4, 2016 1 hour ago, JZH said: LOL, are you married? I sure wouldn't be if I tried to use the kitchen sink as a parts washer... Ciao, She didn't mind when it was her bike I was building in there :) Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted May 4, 2016 Member Contributer Share Posted May 4, 2016 we love pictures here! And I dread to think that my swingarm will look the same inside.... One day I will take it apart, one day.... Link to comment Share on other sites More sharing options...
Y282 Posted May 4, 2016 Share Posted May 4, 2016 It was a mare to take apart, locknut needed heating, freezing, cutting, chiselling, chewing... At least now I can get the lot looking tidy tho :) Link to comment Share on other sites More sharing options...
Y282 Posted May 7, 2016 Share Posted May 7, 2016 Thoughts on this back end...? Link to comment Share on other sites More sharing options...
Member Contributer JZH Posted May 7, 2016 Member Contributer Share Posted May 7, 2016 On 29/04/2016 at 7:38 AM, Y282 said: Welding class last night, built up the dogbone ready for redrilling. Before and after... Do you think it was necessary to build up the dogbone width? I'm in need of a shorter dogbone for my RC30 swing arm (93.75mm centre to centre vs OEM RC36 115mm centre to centre), which means the new hole has to be drilled in the portion of the dogbone that is 20mm wide. Having a 10mm margin on either side (per OEM) would obviously be safer, but a 5mm margin still looks okay to me. <dunno> Ciao, Link to comment Share on other sites More sharing options...
Y282 Posted May 7, 2016 Share Posted May 7, 2016 34 minutes ago, JZH said: Do you think it was necessary to build up the dogbone width? I'm in need of a shorter dogbone for my RC30 swing arm (93.75mm centre to centre vs OEM RC36 115mm centre to centre), which means the new hole has to be drilled in the portion of the dogbone that is 20mm wide. Having a 10mm margin on either side (per OEM) would obviously be safer, but a 5mm margin still looks okay to me. <dunno> Ciao, Interesting you ask. I bought an older vfr dogbone off ebay as a backup and it's an exact fit. Hole is about 22mm closer. I'll probly use that instead and keep the modded onein case i want to jack it up even higher. Link to comment Share on other sites More sharing options...
Member Contributer JZH Posted May 8, 2016 Member Contributer Share Posted May 8, 2016 12 hours ago, Y282 said: Interesting you ask. I bought an older vfr dogbone off ebay as a backup and it's an exact fit. Hole is about 22mm closer. I'll probly use that instead and keep the modded onein case i want to jack it up even higher. Do you know which model VFR? "Older" than 3rd gen only leaves a couple of possibilities, though! Ciao, Link to comment Share on other sites More sharing options...
slovcan Posted May 8, 2016 Share Posted May 8, 2016 9 hours ago, JZH said: Do you know which model VFR? "Older" than 3rd gen only leaves a couple of possibilities, though! Ciao, Hi JZH, You need the one from an '86 or '87. The '86 is heavier duty material than the '87 which is like the stock 3rd gen material. I just bought an '86 one with the shock arm (which you don't change, but came with it from this seller). Cheers, Glenn Link to comment Share on other sites More sharing options...
Y282 Posted May 8, 2016 Share Posted May 8, 2016 Just checked, it's off an 86/87. Link to comment Share on other sites More sharing options...
750 Posted May 11, 2016 Share Posted May 11, 2016 On 5/7/2016 at 7:23 PM, Y282 said: Thoughts on this back end...? Don't like it, the frame fins simply do NOT allow for a seat like that and retain the good looks of the bike. This generation wasn't born to be changed like that, the 94-97 was though! Link to comment Share on other sites More sharing options...
Y282 Posted May 12, 2016 Share Posted May 12, 2016 I've left it sat on the bike for a week while i wait for parts to turn up and i must admit, i'm leaning towards staying standard. I'd really like an nc30 style back end tho. Link to comment Share on other sites More sharing options...
Nifty7Fifty Posted May 13, 2016 Author Share Posted May 13, 2016 First time back here in awhile! Awesome work Y282 !!! Your welded dogbone looks perfect ! Glad to see you are testing the 86' dogbone too, I know it's gonna be a real close hit or miss, I haven't had the time to test it... been busy with family, work, and other projects (check me out on YouTube: https://www.youtube.com/user/Glory2America) The new hole on my modded dogbone is exactly 20mm center-to-center from the original hole. IIRC the 86' equates to 22mm? I had all those measurements posted in detail but I see all my pics are missing from this thread?? bummer. I would suggest drilling the new hole 18mm C2C though, if you haven't already done so... I believe 17 - 18mm could be perfect for the ZX14 shock. Here's an update: I have 700 miles on the shock now and it's functioning extremely well and predictable. One thing I figured out, was that I was reading the compression and rebound settings backwards!! So, in my "Test Run" videos, the shock was actually set very soft but it still looked and felt great. I now have the settings right and it's much tighter. I'm 215 lbs. naked, and it handles my weight superbly... My 160 lb. buddy takes it out often and he loves the way it handles too (He keeps begging me to trade him for his mint 2009 Ninja 500R, lol) Link to comment Share on other sites More sharing options...
Y282 Posted May 13, 2016 Share Posted May 13, 2016 1 hour ago, Nifty7Fifty said: First time back here in awhile! Awesome work Y282 !!! Your welded dogbone looks perfect ! Glad to see you are testing the 86' dogbone too, I know it's gonna be a real close hit or miss, I haven't had the time to test it... been busy with family, work, and other projects (check me out on YouTube: https://www.youtube.com/user/Glory2America) The new hole on my modded dogbone is exactly 20mm center-to-center from the original hole. IIRC the 86' equates to 22mm? I had all those measurements posted in detail but I see all my pics are missing from this thread?? bummer. I would suggest drilling the new hole 18mm C2C though, if you haven't already done so... I believe 17 - 18mm could be perfect for the ZX14 shock. Here's an update: I have 700 miles on the shock now and it's functioning extremely well and predictable. One thing I figured out, was that I was reading the compression and rebound settings backwards!! So, in my "Test Run" videos, the shock was actually set very soft but it still looked and felt great. I now have the settings right and it's much tighter. I'm 215 lbs. naked, and it handles my weight superbly... My 160 lb. buddy takes it out often and he loves the way it handles too (He keeps begging me to trade him for his mint 2009 Ninja 500R, lol) Good to see you back mate. I'm going to run the 86/87 first, it's a little over 20mm ctc but i like the back a little taller. i'm cleaning and servicing everything as it goes back on so it'll be a little while now before i can report. what settings for the shock would you advise now? I'm a little confused now based on what you just said about the settings. Want it to feel more like my blade at the back, kind of firmer. I've rebuilt the front forks and overfilled by 5mm on hrc seals. Also I'm 180lbs give or take a meal. Link to comment Share on other sites More sharing options...
Member Contributer JZH Posted May 13, 2016 Member Contributer Share Posted May 13, 2016 I got one last week and the FG-H dogbone is 92mm c-to-c, versus 115mm for the RC36-I version. You're right about it being heavier--the thing weighs a ton! Cast iron, it appears to be. No surprise, then, that the RC30 version (120mm) was made of forged aluminum. Btw, I ended up not using any of the 'bones in my collection. I'm moving the shock mount instead... Ciao, Link to comment Share on other sites More sharing options...
Nifty7Fifty Posted May 13, 2016 Author Share Posted May 13, 2016 It's been a minute, had to check my notes... I believe my comp setting is now 1.25 turns out from hardest setting, and rebound is 1 turn out from hardest. In the initial testing I was 1.25 turns out from softest (I was reading the "H - S" backwards) . I'll double-check the bike to confirm and get back to you. The thing to look out for with the 86' link is if the shock spring contacts the swing arm when fully assembled. 20mm shorter is the max that I can confirm proper (no contact) operation, so the slightly shorter 86' link may bring the shock in a hair too much. If there is slight contact, it may be fine, because when you mount the bike the shock will move away from the swing arm, and you may even be able to file the swingarm slightly... But this is all speculation on my part, it may be fine. Just gotta try it and see how she lines up... Link to comment Share on other sites More sharing options...
Y282 Posted May 13, 2016 Share Posted May 13, 2016 Cheers for that :) Link to comment Share on other sites More sharing options...
Manny Posted May 16, 2016 Share Posted May 16, 2016 Hello everyone, As I too have joined the ninja/viffer. Just ordered mine and will be doing the swap. I am pretty tall at 6'2" and at 225 so I believe I will be going with the dog bone mod with 20mm. I will keep everyone posted. Thanks Nifty and everyone else who has contributed to this mod. Manny Link to comment Share on other sites More sharing options...
Nifty7Fifty Posted May 17, 2016 Author Share Posted May 17, 2016 8 hours ago, Manny said: Hello everyone, As I too have joined the ninja/viffer. Just ordered mine and will be doing the swap. I am pretty tall at 6'2" and at 225 so I believe I will be going with the dog bone mod with 20mm. I will keep everyone posted. Thanks Nifty and everyone else who has contributed to this mod. Manny Hello Manny, Welcome to the party Bro !! Link to comment Share on other sites More sharing options...
Y282 Posted June 6, 2016 Share Posted June 6, 2016 Few mini pics to update. Not much to tell tbh, just cleaning everything as i get chance. One thing to note though is this is the older vfr dogbone and the shock is VERY close to the swingarm. In fact, it's currently touching while the swingarm is suspended in the air with no weight on it... Link to comment Share on other sites More sharing options...
