czargee Posted October 6, 2015 Share Posted October 6, 2015 So I picked up a Rick's stator (pn 21-120) on ebay and the thing doesn't fit. It's considerably larger that the original one. Anyone have the same problem? Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted October 6, 2015 Member Contributer Share Posted October 6, 2015 2002 ? If it is you have to change the rotor also. Link to comment Share on other sites More sharing options...
czargee Posted October 6, 2015 Author Share Posted October 6, 2015 2002 ? If it is you have to change the rotor also. Yes, it's a 2002. By rotor, are you referring to the no. 3 part on the diagram? 2002 ? If it is you have to change the rotor also. If you have a part no./link to the rotor that will work with the Rick's stator, I'd appreciate it! Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted October 6, 2015 Member Contributer Share Posted October 6, 2015 See ... You can send your old one off and have it rewound . Link to comment Share on other sites More sharing options...
czargee Posted October 6, 2015 Author Share Posted October 6, 2015 See ... You can send your old one off and have it rewound . Cool! Will do. Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted October 6, 2015 Member Contributer Share Posted October 6, 2015 These guys do excellent work. http://www.customrewind.com Link to comment Share on other sites More sharing options...
Member Contributer Cogswell Posted October 7, 2015 Member Contributer Share Posted October 7, 2015 Kaldek has a topic about changing out the 2002 stator and flywheel. It's probably worth doing for the higher output - the reason Honda changed in later years. +1 on Custom Rewind. Before sending it to them, consider what kind of connector you want to use - they'll put about anything you want on it. You can also ask for a bit extra wire in the event you need to cut a connector off and replace it. Link to comment Share on other sites More sharing options...
Member Contributer Havagan Posted October 7, 2015 Member Contributer Share Posted October 7, 2015 How confident are you in the eBay seller? I purchased a Rick's 21-120 for my 2002 and it installed perfectly. Nothing replaced but the stator and the 10-126H-1 R/R. Link to comment Share on other sites More sharing options...
sudo Posted October 7, 2015 Share Posted October 7, 2015 How confident are you in the eBay seller? I purchased a Rick's 21-120 for my 2002 and it installed perfectly. Nothing replaced but the stator and the 10-126H-1 R/R. Your bike's previous owner probably had the AC Generator Update performed. Check for punch marks on the VIN plate. More info here: https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CB0QFjAA&url=http%3A%2F%2Fwww.vfrdiscussion.com%2Fforum%2Findex.php%3Fapp%3Dcore%26module%3Dattach%26section%3Dattach%26attach_id%3D1801&ei=z-ycU6fFM8u3yATO6YGoDA&usg=AFQjCNFunh5naxR9ufreeA1wYwVM5Fhzbg&sig2=p0G2NOLUI8FltLM-CUQczw Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted October 8, 2015 Member Contributer Share Posted October 8, 2015 How confident are you in the eBay seller? I purchased a Rick's 21-120 for my 2002 and it installed perfectly. Nothing replaced but the stator and the 10-126H-1 R/R. Your bike's previous owner probably had the AC Generator Update performed. Check for punch marks on the VIN plate. More info here: https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CB0QFjAA&url=http%3A%2F%2Fwww.vfrdiscussion.com%2Fforum%2Findex.php%3Fapp%3Dcore%26module%3Dattach%26section%3Dattach%26attach_id%3D1801&ei=z-ycU6fFM8u3yATO6YGoDA&usg=AFQjCNFunh5naxR9ufreeA1wYwVM5Fhzbg&sig2=p0G2NOLUI8FltLM-CUQczw You can tell by the pic's. Link to comment Share on other sites More sharing options...
Member Contributer Doc4216 Posted October 8, 2015 Member Contributer Share Posted October 8, 2015 Let me know if you don't use the stator...I might be in need of one Link to comment Share on other sites More sharing options...
PACIFICMAN Posted October 8, 2015 Share Posted October 8, 2015 All advice above, I'm sure, is top notch. For my '02 I went with all Honda factory parts, stator and rotor, it was plug and play and not much more costly. I think I got my local dealer to match Partzilla, which was close to the price on the aftermarket stator. And much less than list for the whole "kit" from Honda (gasket included). Sold that bike, but it worked flawlessly for 18 months... Link to comment Share on other sites More sharing options...
czargee Posted October 10, 2015 Author Share Posted October 10, 2015 How confident are you in the eBay seller? I purchased a Rick's 21-120 for my 2002 and it installed perfectly. Nothing replaced but the stator and the 10-126H-1 R/R. Your bike's previous owner probably had the AC Generator Update performed. Check for punch marks on the VIN plate. More info here: https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CB0QFjAA&url=http%3A%2F%2Fwww.vfrdiscussion.com%2Fforum%2Findex.php%3Fapp%3Dcore%26module%3Dattach%26section%3Dattach%26attach_id%3D1801&ei=z-ycU6fFM8u3yATO6YGoDA&usg=AFQjCNFunh5naxR9ufreeA1wYwVM5Fhzbg&sig2=p0G2NOLUI8FltLM-CUQczw Didn't see a punch.Let me know if you don't use the stator...I might be in need of one Will do! Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted October 11, 2015 Member Contributer Share Posted October 11, 2015 How confident are you in the eBay seller? I purchased a Rick's 21-120 for my 2002 and it installed perfectly. Nothing replaced but the stator and the 10-126H-1 R/R. Your bike's previous owner probably had the AC Generator Update performed. Check for punch marks on the VIN plate. More info here: https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CB0QFjAA&url=http%3A%2F%2Fwww.vfrdiscussion.com%2Fforum%2Findex.php%3Fapp%3Dcore%26module%3Dattach%26section%3Dattach%26attach_id%3D1801&ei=z-ycU6fFM8u3yATO6YGoDA&usg=AFQjCNFunh5naxR9ufreeA1wYwVM5Fhzbg&sig2=p0G2NOLUI8FltLM-CUQczw Didn't see a punch.Let me know if you don't use the stator...I might be in need of one Will do! It is the stock stater and rotor for a 2002 . Link to comment Share on other sites More sharing options...
