6Th Gen Seized Idle Adjustment Knob
Skids
Has anyone had any issue with the knurled knob at the end of the idle adjustment on a 6th Gen seizing? Mine wont turn at all.
I've not had time to remove the airbox to take a look but just wondered if this was a known issue and if there were any known fixes.
Thanks.
Gareth, the problem will be at the fuel injection end, been there/done that. It will not be the cable from the knob as this is not a Bowden cable within a sheath, it is a single semi ridgid cable.
Mine was seized at the throttle body end quick spray and soak with a penetrating oil and all is silky smooth and turns easily
On my 2004 the adjuster is what looks like a mild steel screw on the end of the adjuster into an aluminium thread on the throttle body
