Member Contributer dutchinterceptor Posted May 15, 2015 Member Contributer Share Posted May 15, 2015 I'm hoping to mount a set of 6th gen Pazzo shorty levers on a 5th gen. The clutch lever is the same but the brake lever is different. I found where I can order the main section of the lever and was hoping one of you would be so kind as to give me the part number stamped on it. I think it's (F-XX) but wanted to confirm before I order. I'm thinking it might require removal to see the part # or look at it from underneath. Thanks a bunch!! Link to comment Share on other sites More sharing options...
Member Contributer vfrurknee Posted May 15, 2015 Member Contributer Share Posted May 15, 2015 Dutch, I pulled the front brake master cylinder but find no numbers resembling F-XX. The body of the master cylinder toward the front from the handlebar mount has an H-19 stamped on the body of the reservoir. Actually the older bike has H-13 stamped same location. Can't find a Honda PN in any of my manuals. By older I mean the bike with the lower vin number. They were probably both manufactured/assembled on the same day. If it is any help the brake and clutch masters are mirror images. Don't know anything about the 6th gens! If you need more details PM me! Link to comment Share on other sites More sharing options...
Member Contributer dutchinterceptor Posted May 15, 2015 Author Member Contributer Share Posted May 15, 2015 Thanks Ernie! I didn't explain myself well enough. It's the part of the Pazzo lever that actually mounts into the perch that I'm looking for. On the bottom side it should have the part number stamped into it. I'll give you a call tomorrow. Link to comment Share on other sites More sharing options...
Member Contributer panamawing Posted May 15, 2015 Member Contributer Share Posted May 15, 2015 Dutch, I installed my pazzo shorties from my 6th gen on my 4th gen. No issues plug and play. Link to comment Share on other sites More sharing options...
Member Contributer jeffyjeff Posted May 15, 2015 Member Contributer Share Posted May 15, 2015 Confirmed, the number on the brake lever base is F-XX. Installed on my 5th gen. Link to comment Share on other sites More sharing options...
Member Contributer dutchinterceptor Posted May 15, 2015 Author Member Contributer Share Posted May 15, 2015 Dutch, I installed my pazzo shorties from my 6th gen on my 4th gen. No issues plug and play. The actuator pin on this 5th gen I'm working on is different from the 6th gen. It has a ball on the end that fits into a socket on the brake lever. The 6th gen lever doesn't have a provision to keep the pin in place. I'll get pics when I get back to my shop. Confirmed, the number on the brake lever base is F-XX. Installed on my 5th gen. Thanks very much for the confirmation Jeffyjeff. Link to comment Share on other sites More sharing options...
wera803 Posted May 15, 2015 Share Posted May 15, 2015 The left lever is 4th & 6th gen. The right is a 5th gen lever. Link to comment Share on other sites More sharing options...
Member Contributer Terry Posted May 17, 2015 Member Contributer Share Posted May 17, 2015 Just like this on my '99: Link to comment Share on other sites More sharing options...
