Corey Posted February 9, 2015 Share Posted February 9, 2015 Givi 257FZ rack and M5 Monokey plate. I followed the instructions, but maybe I somehow got the installation wrong. After attaching the M5 Monokey plate to the 257FZ rack...the nuts are underneath the plate and can easily be untightened/removed to lift and steal the whole topcase. Is there another more secure option for mounting the Monokey plate? Are the nuts supposed to be underneath like that? Link to comment Share on other sites More sharing options...
Guest Posted February 9, 2015 Share Posted February 9, 2015 Try to unscrew them. What you will find is once they are loose the hex head bolt will start to spin freely. The nut should be a nylon lock nut. It won't come off if there isn't a wrench on the bolt. Link to comment Share on other sites More sharing options...
duccmann Posted February 10, 2015 Share Posted February 10, 2015 Thought the same thing installing mine, put a dab of lock tight on each nut. That didn't sound right... :-)...... Link to comment Share on other sites More sharing options...
Member Contributer VFRMAN Posted February 10, 2015 Member Contributer Share Posted February 10, 2015 Just about to order the givi rack and monokey plate now, was it difficult to install? Link to comment Share on other sites More sharing options...
marriedman Posted February 10, 2015 Share Posted February 10, 2015 Always remember, locking luggage is only enough to deter a lazy thief and keep honest people honest. An old style sharpened can opener would cut through hard luggage with no problems. If you are worried about luggage being stolen, take them inside if possible! edited to add picture Link to comment Share on other sites More sharing options...
Corey Posted February 10, 2015 Author Share Posted February 10, 2015 Just about to order the givi rack and monokey plate now, was it difficult to install? The installation was straight forward. Just don't tighten everything down until it is all connected to the bike. And when you tighten it, do a little at a time alternating between each piece. One caveat... I see you've already read it, but you might want to revisit my contributions to this post regarding drilling the left support bracket (Part17) to fit the bottle-nosed spacer (Part 8) correctly. 5Th Gen Givi Monorack Install Question Link to comment Share on other sites More sharing options...
Member Contributer gll429 Posted February 10, 2015 Member Contributer Share Posted February 10, 2015 if you are really worried about it.. this is my " BE SURE YOU HAVE IT WHERE YOU WANT IT" METHOD, change the hardware to allen button heads.. install the button heads from the out side.. use lock tight on the nets.. shave excess bolt off.. fill in the allen key "hole" with jb weld and place tape over it until it hardens.. paint the head black to match the rack.. yep! time consuming for anyone to remove it.. Link to comment Share on other sites More sharing options...
Member Contributer didit Posted February 10, 2015 Member Contributer Share Posted February 10, 2015 Always remember, locking luggage is only enough to deter a lazy thief and keep honest people honest. An old style sharpened can opener would cut through hard luggage with no problems. If you are worried about luggage being stolen, take them inside if possible! edited to add picture +1 I did the reverse install on mine, cutting the excess off and JB weld on the head. If they want it bad enough it will disappear, but at least I know it won't fall off at 128 mph. Link to comment Share on other sites More sharing options...
VFR4Lee Posted February 11, 2015 Share Posted February 11, 2015 I figure it's secure enough to leave on the bike while getting lunch. But not enough to leave on the bike overnight outside a motel. Link to comment Share on other sites More sharing options...
