Member Contributer Dutchy Posted September 18, 2014 Member Contributer Share Posted September 18, 2014 I would like to swap the bolts on top of the clutch springs I assume that the basket is aluminium and no idea what the oem bolts are made off so what material should the bolt be? aluminum? Maybe too weak for the application? Stainless steel? maybe corrosion with the aluminum? does not matter? Quote Link to comment Share on other sites More sharing options...
SEBSPEED Posted September 18, 2014 Share Posted September 18, 2014 I would not use aluminum. I might use stainless, although the uncoated stainless would react with the aluminum over time. Probably over a long time given the oil bath... The oem bolts are mild steel, zinc coated. Quote Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted September 18, 2014 Author Member Contributer Share Posted September 18, 2014 Cheers! SS Bolts ordered (INOX A4 Torx), will post up the "new look" clear clutch cover as soon as I have the parts in my grubby little hands.... Quote Link to comment Share on other sites More sharing options...
V4 Rosso Posted September 18, 2014 Share Posted September 18, 2014 Plain SS and not some coloured bolts (white & blue to stay with the theme )? e.g. Gilex in Amsterdam sells Ti and high grade aluminium Poggipolini bolts in various colours. Quote Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted September 18, 2014 Author Member Contributer Share Posted September 18, 2014 patience grasshopper, patience! Quote Link to comment Share on other sites More sharing options...
Roebling3 Posted September 18, 2014 Share Posted September 18, 2014 Though I've met but few Netherlanders even those I've not met put a smile on my face. Thanx guys. Good fortune, R3~ Quote Link to comment Share on other sites More sharing options...
bluewaffle Posted September 18, 2014 Share Posted September 18, 2014 Ordered all my counter sunk stuff!! Thanks for all the help with measurements dutchy! Quote Link to comment Share on other sites More sharing options...
VFRBert Posted September 18, 2014 Share Posted September 18, 2014 patience grasshopper, patience! I will put my sunnglasses on sunday, all those shiny colors will get my brains confused. Quote Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted September 18, 2014 Author Member Contributer Share Posted September 18, 2014 I suggest you ride in front of me, the Akra does give a bit more sound..... (Confused what we are talking about? VFRBert and I are joining a VFR ride-out, some 30 expected to show up...) Quote Link to comment Share on other sites More sharing options...
VFRBert Posted September 18, 2014 Share Posted September 18, 2014 My bike runs on a rich mixture, oxygene bottle advised. Quote Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted September 20, 2014 Author Member Contributer Share Posted September 20, 2014 Next question.... If one fits stronger clutch springs (like +10%), do you still torque the bolts to the spec as per the manual? Quote Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted September 20, 2014 Share Posted September 20, 2014 if you overtighten the bolts, you risk damaging the clutch basket. I put in an aftermarket clutch and springs, torqued to spec, zero problems. http://www.vfrdiscussion.com/forum/index.php/topic/68154-clutch-and-grab/ Quote Link to comment Share on other sites More sharing options...
V4 Rosso Posted September 20, 2014 Share Posted September 20, 2014 If one fits stronger clutch springs (like +10%), do you still torque the bolts to the spec as per the manual?Yes, as in this configuration the torque value has no relation to the spring tension. Quote Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted September 20, 2014 Author Member Contributer Share Posted September 20, 2014 Thanks, bedankt!!! Quote Link to comment Share on other sites More sharing options...
