Member Contributer mandavdle Posted August 25, 2014 Member Contributer Share Posted August 25, 2014 Got my new 1200 bike home, checked the oil and found the level to be too high in the sightglass. Drained off about 150cc, now at top line in sightglass. How bad is too much oil in this bike, anyway? Oops, wrong section ... Link to comment Share on other sites More sharing options...
Member Contributer Duc2V4 Posted August 25, 2014 Member Contributer Share Posted August 25, 2014 Got my new 1200 bike home, checked the oil and found the level to be too high in the sightglass. Drained off about 150cc, now at top line in sightglass. How bad is too much oil in this bike, anyway?Oops, wrong section ... We just had a similar case not too long ago, long story short, not too much to worry about but something to be cognizant of on the next oil change. Link to comment Share on other sites More sharing options...
Member Contributer BusyLittleShop Posted August 25, 2014 Member Contributer Share Posted August 25, 2014 too much oil may escape the breather and end up in the air box... oil in the air box may become ingested into the cylinders and cause white smoke out the exhaust... if you have none of these signs then your high oil level is not a problem... Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted August 26, 2014 Member Contributer Share Posted August 26, 2014 But if it gets to the starter valves, ruff, very ruff idle. Dont ask how I know . Link to comment Share on other sites More sharing options...
RobertoRC46 Posted October 22, 2014 Share Posted October 22, 2014 150cc won't hurt your motor definitely. Keep in mind on the next oil cahnge that you should set the level just below the upper level line or even at the 3/4 of the distance between the two lines (lower - upper). Link to comment Share on other sites More sharing options...
Auspanyol Posted June 1, 2015 Share Posted June 1, 2015 Any mods wanna move this to the right sección? Link to comment Share on other sites More sharing options...
