house Posted August 1, 2014 Share Posted August 1, 2014 If you are looking for more information on the factory accessories for the 8th gen, I stumbled on the online manuals/installation instructions today. You can find them here: http://cssportal.css-club.net/honda/MCA/start.asp?group=oth (they have a few other bikes listed as well.) ACCESSORY SOCKET.pdf CARRIER BRACKET.pdf CARRIER BRACKET 45L.pdf HANDLE ADJUST PLATE.pdf HUGGER.pdf PANNIER SET (Wave key type).pdf QUICK SHIFTER.pdf SECURITY ATTACHMENT.pdf TOP BOX (Wave key type).pdf Link to comment Share on other sites More sharing options...
garyr Posted August 11, 2014 Share Posted August 11, 2014 Thanks for posting this, used it to fit my hugger and the rubber backrest for my topbox. Just to buy the risers, akro can and pazzo levers (when they come out). Link to comment Share on other sites More sharing options...
Member Contributer Rectaltronics Posted August 11, 2014 Member Contributer Share Posted August 11, 2014 I'm grateful for the info too. Without this I might have wasted money on a useless power socket. GeeZ...! Link to comment Share on other sites More sharing options...
garyr Posted August 11, 2014 Share Posted August 11, 2014 I'm grateful for the info too. Without this I might have wasted money on a useless power socket. GeeZ...! I got one, it comes with the touring package. It is only live if the engine is on!! . Dont understand why they did not put a socket or 2 on the outside of the bike somewhere. Link to comment Share on other sites More sharing options...
Member Contributer Rectaltronics Posted August 11, 2014 Member Contributer Share Posted August 11, 2014 Touring package. Never heard of that. Guess that's not an option in the 'States? Link to comment Share on other sites More sharing options...
Member Contributer Rectaltronics Posted August 20, 2014 Member Contributer Share Posted August 20, 2014 Beware, the side cases are only rated to carry 13.2 lbs each. Two gallons of milk, better put one in each!!! $#!+.... Link to comment Share on other sites More sharing options...
Shinigami Posted August 21, 2014 Share Posted August 21, 2014 Yes that pannier weight limit is a little disconcerting. I suppose the dynamics acting on the panniers in bumps must have led to a conservative limit. Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted August 22, 2014 Member Contributer Share Posted August 22, 2014 Handle spacer will be easy to reproduce right Seb ... Link to comment Share on other sites More sharing options...
Aspon Posted October 31, 2014 Share Posted October 31, 2014 Thanks for info very useful ! Link to comment Share on other sites More sharing options...
Member Contributer Rectaltronics Posted November 1, 2014 Member Contributer Share Posted November 1, 2014 Moving the pannier locks. Hopefully none of you have to go through this but due to a taxicab passenger not looking before swinging her door WIDE open, I ended up having to replace my panniers. Naturally I bought just the panniers and planned on moving the key lock cylinders from the old set to the new set. That as it turns out is do-able but not entirely without effort. The objective is to reach what the instructions refer to as the stopper tumbler while the key is in the inner cylinder. Depressing that tumbler into the cylinder is what allows you to remove the inner cylinder so it can be moved to the new panniers. Often, the outer cylinder will have some hole or slot cut into the side so once you can access the outer cylinder, you can push something in to release the inner cylinder. To reach that inner cylinder you have to completely disassemble the locking mechanism from inside the bag. You'll need hex and Torx bits. Then you'll discover that the outer cylinder has no hole or slot in the side. There's a circlip on the back of the inner cylinder which fastens it to the actuator arm for the lock and bag release mechanism. Remove it the circlip and move the mechanism away, wipe away some of the grease in the slot underneath and you should be able to see that stopper tumbler. I used a toothpick in the slot while rotating the key / inner cylinder to depress the tumbler. A paperclip in the little hole at the end of the outer cylinder helps push the inner cylinder out from behind. Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted December 13, 2014 Member Contributer Share Posted December 13, 2014 ? Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted December 13, 2014 Member Contributer Share Posted December 13, 2014 szdegvSgvb 2013 VFR1200 Blue bags .. Link to comment Share on other sites More sharing options...
Member Contributer Blesk Posted December 14, 2014 Member Contributer Share Posted December 14, 2014 So what is the Security Attachment if the Alarm is "sold separately"? Is that just the bracket to attach the Honda alarm?? Also, I don't mind having the electrical outlet switched off when the bike it off. All I use it for is charging things while I'm riding. I wouldn't leave something charging while I'm away from the bike. Link to comment Share on other sites More sharing options...
Allyance Posted December 19, 2014 Share Posted December 19, 2014 Can not find any reference to the "Security Attachment" (Alarm System) on Honda's web site or accessory catalog. Searched part number and no results! Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted December 19, 2014 Member Contributer Share Posted December 19, 2014 Can not find any reference to the "Security Attachment" (Alarm System) on Honda's web site or accessory catalog. Searched part number and no results! Only Europe ME THINK. http://www.cmsnl.com/products/kit-security-att_08e70mjmd00/#.VJStxdwBpA Link to comment Share on other sites More sharing options...
Sixbeans Posted December 27, 2014 Share Posted December 27, 2014 Has anyone bought and installed the Rear Carrier, Rear Trunk Base and Rear Trunk on their 2014 Interceptor and if so are you happy with it? Quite costly (in my opinion) but might be nice for longer rides. I have the side panniers on my bike and am very happy with them. A friend following me did comment that it seemed to him that they flex/bounce up and down quite a bit when I go over bumps. Based on that I have considered adding a removable support strut between the base of the panniers to cut down this flex. Should be fairly easy to avoid any interference with the rear tire. Thoughts welcome! I wonder if this "flex" is the basis for the capacity limit on the panniers, since the mounting brackets seem quite robust. Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted December 28, 2014 Member Contributer Share Posted December 28, 2014 Don't know about reinforcing but flex is bad so yeah I would have to try something. Link to comment Share on other sites More sharing options...
Viffertje Posted December 30, 2014 Share Posted December 30, 2014 Has anyone bought and installed the Rear Carrier, Rear Trunk Base and Rear Trunk on their 2014 Interceptor and if so are you happy with it? Quite costly (in my opinion) but might be nice for longer rides. I have the side panniers on my bike and am very happy with them. A friend following me did comment that it seemed to him that they flex/bounce up and down quite a bit when I go over bumps. Based on that I have considered adding a removable support strut between the base of the panniers to cut down this flex. Should be fairly easy to avoid any interference with the rear tire. Thoughts welcome! I wonder if this "flex" is the basis for the capacity limit on the panniers, since the mounting brackets seem quite robust. indeed that is why the panniers have a limit to max. wheight. Link to comment Share on other sites More sharing options...
