Dot5 For Clutch?
tomk1960
I first put DOT 5 silicone brake fluid in my FJ about 15 years ago. I've had no leaks, and brakes and clutch work fine. Maybe I just got lucky,
but that is my experience. I never changed any of the seals before I went to silicone fluid, just flushed things as well as I could.
no you didnt get lucky..
well maybe for the lines.
here ths thing the dot 3/4 as people keep pointing out.. absorbs moister.. meaning it also shrinks rubber seals.. silicon will counter that effect when mixed by mistake with dot 3/4 making the seals expand to far and making hoses rubbery... thus effecting the power of the brakes
If you mix silicone fluid with DOT 3/4 fluid you have a serious situation. The result is a semi-viscous mess that can really screw up things.
It didn't happen to me but I did get some silicone fluid mixed in with DOT 3/4 in a container and ended up with lumps of nasty stuff on the
bottom. I don't know what would happen if that occurred in brake lines/calipers, but it couldn't be good.
yes. but its NOT instant. in fact it can take months .,
whats happens sooner is the chem reaction to the lines and seals. :wink:
"Protecting the paint" sounds like a bizarre reason to switch brake fluids. The only time I've ever damaged anything with brake fluid was when I tried to blow out some caliper pistons with compressed air--never tried that again!
Ciao,
you never had a $20,000 paint job
and dot 3 or 4 will leave stains and eventually destroy the area it keeps dripping on.. as the poster says his bike weeps it..
Oh, I dunno...maybe I'd just fix the bloody leak? :unsure:
Ciao,
Ciao,
Ciao,
yep and when you change the fluid and miss a rop..( god forbid).. and it screws up your perfect NR750, dont blame me. :wink:
Ciao,
Ciao,
You got me. Okay, if I ever get an NR, yes I will switch to sillycone brake fluid... :happy:
Ciao,
