Member Contributer Knute Posted March 18, 2014 Member Contributer Share Posted March 18, 2014 Howdy all, I'm in the process of installing motad header on my '04. I got the old system off with only one little issue, one stud came out with the nut, should install a new stud and and get a new nut, or just reinstall the old stud with the nut attached? And... would it be advisable to use anti seize compound during installation? Really appreciate any advice anyone might have. Knute Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted March 18, 2014 Share Posted March 18, 2014 When I had my headers off, I had a couple of studs that came right out of the block with the nuts. I put anti-sieze on those studs and screwed them right back in again afterwards. And of course, more anti-sieze on the other nuts that came off OK elsewhere. IIRC, the torque is 9 ft/lbs. Worked for me! In this application, it doesn't really matter which end comes apart, as long as nothing snaps. Link to comment Share on other sites More sharing options...
Member Contributer Knute Posted March 18, 2014 Author Member Contributer Share Posted March 18, 2014 When I had my headers off, I had a couple of studs that came right out of the block with the nuts. I put anti-sieze on those studs and screwed them right back in again afterwards. And of course, more anti-sieze on the other nuts that came off OK elsewhere. IIRC, the torque is 9 ft/lbs. Worked for me! In this application, it doesn't really matter which end comes apart, as long as nothing snaps. Thank for the reply Canuck. That's what I was thinking to do too, but thought it best to bounce it off the board first, just in case... Thanks again! Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted March 18, 2014 Member Contributer Share Posted March 18, 2014 If you had to remove the bolts after a short while yeah but wont last long on exhaust .. Link to comment Share on other sites More sharing options...
Member Contributer JZH Posted March 18, 2014 Member Contributer Share Posted March 18, 2014 I have to say that I've done that, too, but it's not the right way to do it! You're basically replacing a nut and stud system with a simple screw. Here's a good explanation. Ciao, Link to comment Share on other sites More sharing options...
Member Contributer Knute Posted March 18, 2014 Author Member Contributer Share Posted March 18, 2014 I have to say that I've done that, too, but it's not the right way to do it! You're basically replacing a nut and stud system with a simple screw. Here's a good explanation. Ciao, Thanks for that! Some great info. Link to comment Share on other sites More sharing options...
