makenzie71 Posted February 27, 2014 Share Posted February 27, 2014 I picked up a '98 800 from a police auction...no keys. Will this model require me to wire in a resistor to bypass the ignition switch? I need to see if the thing will run at all before I can decide exactly what I'm going to do with it. Link to comment Share on other sites More sharing options...
Member Contributer gmtech94 Posted February 27, 2014 Member Contributer Share Posted February 27, 2014 you should be able to remove ignition switch ,seperate it from key part and use a screwdriver to turn on the ignition getting it to run or hopefully run .Also on the back of the switch you will find a code from which a key can be cut . Link to comment Share on other sites More sharing options...
makenzie71 Posted February 27, 2014 Author Share Posted February 27, 2014 I'll try that, gmtech, but I've had terrible luck in the past with trying to take apart the switches. Link to comment Share on other sites More sharing options...
AB-Oz Posted February 27, 2014 Share Posted February 27, 2014 I've just taken apart my ignition on my 99 to swap out the barrell part for one I got from ebay. I had to space the 2 parts with washers to get it to turn properly, and again when fitting back to the bike with washers to get the steering lock to engage. The good news is the 98-99 dont have HISS, so its just a matter of getting keys cut or fitting a new ignition. Link to comment Share on other sites More sharing options...
Member Contributer mk2davis Posted February 27, 2014 Member Contributer Share Posted February 27, 2014 Do you have a service manual? Usually, you can tell what wires need to be jumped from the wiring diagram. Link to comment Share on other sites More sharing options...
makenzie71 Posted February 27, 2014 Author Share Posted February 27, 2014 Yeah I knew which wires needed to be jumped, but there's usually a theft prevention in the ignition that prevents that. On a lot of bikes you have to add a resistor...100ohm with an EX500 for example...to get it to work. And wow that was easy. With a hammer and a good screwdriver I can start any '98 VFR800. That's almost disconcerting. Link to comment Share on other sites More sharing options...
Crewwolfy Posted March 24, 2014 Share Posted March 24, 2014 I just removed/reinstalled my ignition switch last night. Simple swap, though it does involve removing the headlight cowl. Considering your screwdriver/hammer experience, I'll be using the disc lock every time I park from now on.. Link to comment Share on other sites More sharing options...
makenzie71 Posted September 7, 2014 Author Share Posted September 7, 2014 Alright sorry to bump a very old thread BUT...I decided to use this motor in my minibuggy (the bike really was garbage). But, somewhere along the way I have lost that ignition switch. Can anyone confirm if there is a resistor or some sort of anti-theft thing going on with it? I would like to wire it into the buggy's factory ignition if I can. Link to comment Share on other sites More sharing options...
