Guest sunnidog Posted October 10, 2013 Share Posted October 10, 2013 Just upgraded my vf1000 5.5 wheels forks and brakes what do you think Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted October 10, 2013 Member Contributer Share Posted October 10, 2013 Looks great. Still need to set the fork height ? And WELCOME if have not WYH ya.(Welcome you here) Link to comment Share on other sites More sharing options...
Member Contributer CBVFRbikeboy Posted October 11, 2013 Member Contributer Share Posted October 11, 2013 Nice swap. When you get a chance could you provide some details on donor parts and fitting issues? cheers ian Link to comment Share on other sites More sharing options...
Member Contributer JamieDaugherty Posted October 15, 2013 Member Contributer Share Posted October 15, 2013 Looks great! Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted October 15, 2013 Share Posted October 15, 2013 Now for some pictures out in the sun....... Link to comment Share on other sites More sharing options...
Guest Posted October 16, 2013 Share Posted October 16, 2013 Jamie is probably going to say it will not work but hey ho you do not know till you try. Basic parts vfr400 nc30 fork sliders and cartridges, xl600 fork tubes (sort of trails /roadster) the tubes are 1" longer than the vf Extended the cartridges by 6" i have now got preload and rebound adjustment, f4i front wheel, vtr1000 disc/ calipers, fitted using rick oliver caliper mounts sonic vf1000r 1.0 fork springs. I have not been for a long test ride yet as i am fiiting a vf1000r swing arm so when that is complete it,s set up time Link to comment Share on other sites More sharing options...
Maximus86 Posted February 17, 2015 Share Posted February 17, 2015 I know I am bringin back a seriously old topic here, but I have found no one else who did this mod, sunnidog.. I need to know Could you please spare some more details? Is this with an f4i wheel or f2? I thought the F4i had 3-spoke wheels? How did you extend the cartridges? Was this straightforward? Any info is very much appriciated Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted February 17, 2015 Share Posted February 17, 2015 He hasn't logged on since Dec 2013. You might not get a reply here. Try his email: johnnuttall2003@yahoo.co.uk Link to comment Share on other sites More sharing options...
Maximus86 Posted February 19, 2015 Share Posted February 19, 2015 Thank you very much! I knew it was a long shot, the email is more then I hoped for, I will contact him and let you know the details! I am currently researching all possible fork mods for this bike, and this one looks very "oem", which I really like. Link to comment Share on other sites More sharing options...
FERALWORKS Posted February 28, 2015 Share Posted February 28, 2015 HI. I bought that bike off John in Jan 2014. I sold it not too long afterwards as the front end setup was woeful. It looked ok except for the rather excessive amount of stanchion poking up above the yoke but the ride was poor, the damping all to cock & the lack of feedback was worrying. Rather than start from scratch with the forks I decided to cut my losses & sell it. I really didn't need another long running project! I now have a VF1000R & wish I'd kept the F to nick the wheels off it for the R ! Previously I owned a VFR750 which had been built by PDQ & featured in Practical Sportsbike. That had CBR6 wheels & GSXR USD forks. Nice bike, so clean you could eat your dinner off it. But even that 'professionally tested' bike had its faults - when you braked really hard the front wheel hit the radiator! Bloody scary! Here's some pics: Dave Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted February 28, 2015 Share Posted February 28, 2015 Welcome Feralworks I miss my '86 a LOT It had 41mm cbr600 forks, brakes and 17" wheels with radials. And it was nearly as clean as yours! Link to comment Share on other sites More sharing options...
Member Contributer Mohawk Posted February 28, 2015 Member Contributer Share Posted February 28, 2015 The joy of front end projects. The simple way to check clearance is easy with RWU forks, remove caps, remove spring, slide wheel all the way up. It should not hit anything by at least 10mm to allow for fork flex. Remember to fit the mudguard before testing this. If you want to drop the yokes down the fork, you can use this test to find out how far you can go when doing a fork oil change. Now with USD forks this is really hard to check. To perform the same check, you have to completely strip the forks, then reassemble with no internals so you can compress the forks when mounted to the bike. Then find the minimum clearance and mark the fork tube. Now strip & reassemble for use, it's obvious your professionally done one was not very professional at all ! Link to comment Share on other sites More sharing options...
Maximus86 Posted March 10, 2015 Share Posted March 10, 2015 It was actually not clear from the previous pictures that the stanchions stuck out this far above the yoke! Thanks for the reply, I also got in contact with John, and he specified the setup a bit further: Hi maxim Honda xl 600 stanchions Honda nc30 fork bottoms Nc 30 damper cartridges x 4 to extend the length use just the rods to extend rvf front wheel vtr 1000- disc& calipers with rick oliver caliper mounting conversion vf1000r sonic springs (linear) Stanchions modifyed to accept the dampers regards Link to comment Share on other sites More sharing options...
