VFRFahnder Posted October 1, 2013 Share Posted October 1, 2013 I picked up a new-to-me 98 VFR. The grip comes too close to the tank on one side. I want to loosen the pinch bolts and see if the bars will straighten out. I have a manual en route from eBay so I cannot determine the spec at this time. (Also, the online manual link on the forum is taking forever to download.) Any help would be appreciated. Link to comment Share on other sites More sharing options...
Member Contributer vfrurknee Posted October 1, 2013 Member Contributer Share Posted October 1, 2013 26 N-m, or 20 lb/ft. Link to comment Share on other sites More sharing options...
VFRFahnder Posted October 1, 2013 Author Share Posted October 1, 2013 10-4. I appreciate it. Link to comment Share on other sites More sharing options...
Member Contributer zupatun Posted October 2, 2013 Member Contributer Share Posted October 2, 2013 20 ft.lb seemed too high. I checked three references in my Honda manual. One says 20 ant three others say 16ft-lb. Similar bolts into Aluminum are also marked at 16 ft-lb... Anyone else confirm 20ft-lb or 16-ft-lb? Link to comment Share on other sites More sharing options...
Member Contributer mello dude Posted October 2, 2013 Member Contributer Share Posted October 2, 2013 Pinch bolt bar spec = 20 ft -lbs from my FSM Link to comment Share on other sites More sharing options...
Member Contributer vfrurknee Posted October 2, 2013 Member Contributer Share Posted October 2, 2013 The numbers I quoted are from the Honda Service Manual, page 13-2. The Handlebar pinch bolt is the first value listed at the top of the page just below the TORQUE VALUES heading. Link to comment Share on other sites More sharing options...
Member Contributer zupatun Posted October 2, 2013 Member Contributer Share Posted October 2, 2013 I read Fork pinch bolts as...axle pinch bolts...my bad. Axle pinch bolts are 16 ft-lb...fork pinch bolts are as you state 20 ft-lb. Apologies for my confusion. Link to comment Share on other sites More sharing options...
Mrbiggabit Posted September 17, 2015 Share Posted September 17, 2015 According to the Haynes manual and the the service manual which I've just downloaded because i doubted the Haynes setting for the bottoms... The top pinch bolts should be 23 Nm and the bottom pinch bolts 49 Nm The relevant torque settings are on page 20 of the 98-01 service manual hope this helps. Cheers Link to comment Share on other sites More sharing options...
V4 Rosso Posted September 17, 2015 Share Posted September 17, 2015 Here are the relevant pages from the Honda Service Manual VFR_800Fi_98-01_Service_Manual-fork-torque-spec.pdf Link to comment Share on other sites More sharing options...
Member Contributer zupatun Posted September 17, 2015 Member Contributer Share Posted September 17, 2015 resurrected from the dead of threads... Link to comment Share on other sites More sharing options...
