Guest Jerseyt Posted May 6, 2013 Share Posted May 6, 2013 Hi there I'm newI've inherited 4th gen Vfr 750 my dad tried to strip it down and turn into a track bike he stripped the wiring loom and took the clocks apart and cut it up just to run the rev counter. With most of the parts missing fairings and other minor parts I thought to turn it into a street fighter would be easiest option.So what is the easiest digital dash to fit I see these ones that you have to put a sensor on the brake disc for speed what model can you just wire up?Any help is appreciatedMike Quote Link to comment Share on other sites More sharing options...
nexzzt Posted May 6, 2013 Share Posted May 6, 2013 What year is the bike? 5th gen VFRs are 800s. I believe 750s are 3rd or 4th gen depending on the year. Quote Link to comment Share on other sites More sharing options...
Guest Jerseyt Posted May 6, 2013 Share Posted May 6, 2013 Sorry it's a 96 Quote Link to comment Share on other sites More sharing options...
Member Contributer mello dude Posted May 7, 2013 Member Contributer Share Posted May 7, 2013 Sorry it's a 96 Its a 4th gen.... Quote Link to comment Share on other sites More sharing options...
Member Contributer gll429 Posted May 7, 2013 Member Contributer Share Posted May 7, 2013 if your tach works and you just want speedo.. use a back lit bicycle computer, only $20 Quote Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted May 7, 2013 Share Posted May 7, 2013 Edit OP for correct gen. Quote Link to comment Share on other sites More sharing options...
mill159 Posted May 7, 2013 Share Posted May 7, 2013 If I were you, I would look into a Trailtech Vapor. I run one on my DRZ and it has taken continuous abuse for the past two and a half years. Far more than one would ever see on a VFR. The Vapor functions as a speedo (magnetic pick up on the brake), temperature guage, tachometer, clock, lap timer, trip meter, and an odometer. There may be another function I'm missing...idk. You can purchase the unit for around $90 new. I ditched the plastic bar clamp that came with mine and cut a piece of aluminum to mount it to. If you want, Trailtech even sales a dash mount for an additional $40. Look around on sites like ADVrider, Tthumpertalk, and Fleabay. You may be able to pick one up used for a much more reasonable price. Quote Link to comment Share on other sites More sharing options...
Guest Jerseyt Posted May 7, 2013 Share Posted May 7, 2013 Thanks mill159 But I don't really want to run a wire down the fork leg are there none that just wire in? Quote Link to comment Share on other sites More sharing options...
Member Contributer gll429 Posted May 7, 2013 Member Contributer Share Posted May 7, 2013 bicycle computer wireless speedo. the 4th gen has a mechanical speedo.. so the fastest simplest way is a bike speedo. lots of streetfighters use them. Quote Link to comment Share on other sites More sharing options...
Guest Jerseyt Posted May 7, 2013 Share Posted May 7, 2013 Yeah but I want rev and temp gauge the old clocks have been cut the rev counter is currently all I have but it's electrical taped into a plastic pot I don't fancy trying to make a housing for it Quote Link to comment Share on other sites More sharing options...
Member Contributer gll429 Posted May 7, 2013 Member Contributer Share Posted May 7, 2013 then run the vapor.. all you have to do is wrap the speedo wire around the brake line.. its so easy a caveman can do it . Quote Link to comment Share on other sites More sharing options...
Beck Posted May 7, 2013 Share Posted May 7, 2013 Something's wrong with this picture!............the elder/dad actually goofed up the bike this time?? Must be one of those hipster dads! Quote Link to comment Share on other sites More sharing options...
Guest Jerseyt Posted May 7, 2013 Share Posted May 7, 2013 nar he used to race at isle of man on nortons and on tz350's he was going to strip the starter and everything that wasnt needed. but he stripped the loom right back. then he retired and went to traveling in motorhome round southern spain and i have no clue about what he was doing so there were wires everywhere i thought to take the easy option and get it on the road as i havent been on a bike for a year. plus thanks didnt think to run the cable down the brake line Quote Link to comment Share on other sites More sharing options...
Member Contributer gll429 Posted May 7, 2013 Member Contributer Share Posted May 7, 2013 wow.. i am guessing you are in Warrington england... Quote Link to comment Share on other sites More sharing options...
Guest Jerseyt Posted May 7, 2013 Share Posted May 7, 2013 Yeah Warrington England Quote Link to comment Share on other sites More sharing options...
Member Contributer gll429 Posted May 7, 2013 Member Contributer Share Posted May 7, 2013 hit a breaker yard. get a new harness and a stock dash if you where over here up the road at Warrington PA.. i would take a look at it myself. Quote Link to comment Share on other sites More sharing options...
Guest Jerseyt Posted May 7, 2013 Share Posted May 7, 2013 I've bought harness and ordered rh switch gear and ignition barrel hopefully get it running this weekend. you don't happen to know wether to wire the side stand open or closed Quote Link to comment Share on other sites More sharing options...
Member Contributer gll429 Posted May 7, 2013 Member Contributer Share Posted May 7, 2013 I don't remember.. I think you can just unplug it.. it that doesn't work. Use a test up wire. If that works.. then cut the wires and soilder them up :) Just don't drive with your kickstand down :P Quote Link to comment Share on other sites More sharing options...
Guest Jerseyt Posted January 13, 2014 Share Posted January 13, 2014 Here is what she looks like now think I'm gonna stick a fairing on her and have it as a track bike Quote Link to comment Share on other sites More sharing options...
