BonemanVFR Posted October 23, 2011 Posted October 23, 2011 (edited) Spent a few hours today and got my Stebel Nautilus horn installed. After separating the compressor/motor unit from the horn, I found great spots for it inside the upper right side faring. I had a Stebel Nautilus horn on my FZ6 and I loved it. 139dB of derailing freight train goodness. Enough to wake up the most inattentive driver out there. For this installation I had to separate the motor/compressor from the horn unit. This is done by prying up on the compressor nipple that is inserted into the horn. The compressor was also glued to the plastic horn section, so some additional prying was needed to separate it. What you end up with is two pieces that makes mounting a little easier. Once separated, you simply use rubber tubing and a brass fitting in order to connect the compressor unit to the horn. I purchased a 5/16 rubber tubing and some barbed fittings from Home Depot. I mounted both the horn and the compressor unit in the right side front faring area. By mistake I had ended up taking the compressor unit apart (during my horn separation process). In doing so I found out that all it is is an electric motor that spins a shaft that goes to a 'fan' in the top that pushes air into the horn. So I didn't see any reason for the compressor unit to remain upright. For mounting the horn, I simply used some 3M double sided tape. For the compressor I used some 3M tape as well, but also drilled two holes through the black plastic and secured it with a cable tie. The Stebel comes with a relay and yes you will need one as it can draw up to 20amps!! I used the two existing wires going to the stock horn (light green w/silver dots = +12VDC activated by the horn button and dark green w/silver dots = Ground). I left the stock horn in place. Wiring for the relay is as follows: 85 - Ground 86 - Horn wire - light green w/silver dots = +12VDC activated by the horn button 87 - +12VDC switched (power when ignition is on) 30 - Horn compressor + - terminal on Horn compressor - Ground I hooked up 87 to my FZ1 Fuse Block and set it to switched power so only the horn will work when the ignition is on. You can also wire it so the horn will work with constant 12 VDC so it will work with the ignition off (user preference). I initially used a 7.5Amp fuse, but after 2 test blasts of the horn it blew the fuse. So I now have a 15 Amp fuse and that seems to work fine. - Boneman http://www.bonemanvf...ods/stebel.html Edited October 23, 2011 by BonemanVFR Quote
BonemanVFR Posted November 4, 2011 Author Posted November 4, 2011 (edited) Little video of the horn in action: Edited November 4, 2011 by BonemanVFR Quote
Member Contributer AnikMankar Posted April 17, 2012 Member Contributer Posted April 17, 2012 that is neat...i already have one at the same spot but all intact on the 1998. I am planning to move the compressor behind to the back right cowl. lets see,,, Quote
Member Contributer digitallyhip Posted April 17, 2012 Member Contributer Posted April 17, 2012 [snip] So I didn't see any reason for the compressor unit to remain upright. [/snip] Unfortunately and for reason(s) that I don't understand, there is a need for the compressor to be upright. Stebel says that it needs to be within 15 degrees of vertical, or it will fail prematurely. I have mounted mine on the bolt for the original anemic horn, where it lays back perhaps 16 degrees. I have just installed my third horn. The first lasted about six months, and the second a much better 24 months. Other than the early demise, I really like the mounting spot. Quote
BonemanVFR Posted April 17, 2012 Author Posted April 17, 2012 (edited) Mehhh, it's been working just fine. Guess I'll take my chances. Edited April 17, 2012 by BonemanVFR Quote
KanadianKen Posted April 17, 2012 Posted April 17, 2012 NIcely done. Its been a few years since I did my Stebel install - and it wasn't as easy as yours looks. Thanks for sharing! Quote
V4 Rosso Posted April 17, 2012 Posted April 17, 2012 Didn't see this topic before. That is good to know that the compressor can be separated from the horn. I think this way I can find enough space for it to fit behind the fairings.. Thanks for the write up Quote
Member Contributer jay-d Posted April 17, 2012 Member Contributer Posted April 17, 2012 I wish I took pictures of where I mounted mine. VERY easy if you separate them. All I required additionally was a small L bracket. I'll be taking the front end apart, I might take off the fairings and take some pictures. Essentially, I mounted the compressor where Boneman mounted his horn, perfectly upright. I mounted the horn in the stock location using the stock bracket, I just had to use some heavy duty wire to mount the original bracket to the horn. Quote
smoothsailin Posted April 17, 2012 Posted April 17, 2012 Yeah, I need to upgrade the horns on both my Hondas. Had to dodge a brain-dead four-wheeler during commute home on my ST1100 just yesterday. Pressing the horn button was about as effective at getting the driver's attention as was cursing at them with the face shield of the helmet closed. I wonder how much more it would have cost Mr. Honda to simply install a reasonably good performing horn on the manufacturing line. An extra buck or two? Quote
Member Contributer digitallyhip Posted April 17, 2012 Member Contributer Posted April 17, 2012 I wonder what other people are paying for the Nautilus Compact? Mine was $US54.84 shipped to Washington State (with a relay in the box), which seemed like a very good price. Quote
wera803 Posted April 17, 2012 Posted April 17, 2012 I wonder what other people are paying for the Nautilus Compact? Mine was $US54.84 shipped to Washington State (with a relay in the box), which seemed like a very good price. I just put an Ear Cannon (which came in a Nautilus box) on my girlfriend's VFR. It was $40 plus shipping from Aerostich. Came with the relay and mounting bolt. No wiring or anything though. You could buy that for an additional $12. Quote
