Member Contributer 46alpha Posted August 16, 2011 Member Contributer Share Posted August 16, 2011 This is gonna sound crazy, but I've noticed my front suspension is squeaking over bumps. 6th gen with 20K on it, never had any work done on it. Is it time for some fork work? Link to comment Share on other sites More sharing options...
spud786 Posted August 16, 2011 Share Posted August 16, 2011 This is gonna sound crazy, but I've noticed my front suspension is squeaking over bumps. 6th gen with 20K on it, never had any work done on it. Is it time for some fork work? The most neglected area on the front end is the streering bearing, they will become lose quickly right off the floor, never tighten without performing some sort of servicing. if you really think its the forks squirt some armoral on your seal dust covers. Armoral is outstanding for stiction, and very beneficial to seal life. But at 20,000 your oil is going to be severally trashed, if never changed Link to comment Share on other sites More sharing options...
Member Contributer YoshiHNS Posted August 17, 2011 Member Contributer Share Posted August 17, 2011 Can you replicate it while on the center stand? Link to comment Share on other sites More sharing options...
Member Contributer 46alpha Posted August 17, 2011 Author Member Contributer Share Posted August 17, 2011 Can you replicate it while on the center stand? Nope, just tried. Link to comment Share on other sites More sharing options...
VifferSwiffer Posted July 31, 2013 Share Posted July 31, 2013 Ping. (2 years later ) I have the same problem. Anyone else with experience troubleshooting? Link to comment Share on other sites More sharing options...
Member Contributer MBrane Posted August 1, 2013 Member Contributer Share Posted August 1, 2013 Keep the uppers clean, and the dust seals conditioned. Well that, and change the fork oil at least every 10K. Twice as often if you ride aggressively on bumpy roads. Link to comment Share on other sites More sharing options...
Member Contributer JamieDaugherty Posted August 2, 2013 Member Contributer Share Posted August 2, 2013 Most often this is due to the springs rubbing the inside of the forks. That happens normally but sometimes it results in noise. I would pop the caps off and make sure the springs and spacers are centered properly. Chance are good that will fix it. Link to comment Share on other sites More sharing options...
