I ordered a set of lowering links for my wife's Ninja 500. Due to a poorly written description of the links I ended up with 7075 aluminum flat links (as opposed to 303 stainless steel which was included in the description). I did some research on 7075 aluminum and apparently it is widely used in the aerospace industry for its light weight and high strength.
My question is this: Are these safe to use?
My biggest concern is the hole separation between the inner and outer holes (stock = inner, 2" lower = outer). It is .066" aluminum which seems pretty damn thin to me. If lowering the bike required use of the inner hole I would be more comfortable with that but I have to use the outer hole and my fear is that separation won't be thick enough to hold up very long.
I filed the RMA this morning but I can cancel it easily enough should the consensus be these are safe. TIA as always.
Question
vanion2
6 answers to this question
