flwoolybugger Posted August 24, 2010 Share Posted August 24, 2010 Looking to get a carb sync tool. Does anyone have a particular model that I should look for or avoid? Any recommendations? Thanks, Link to comment Share on other sites More sharing options...
Member Contributer k1c Posted August 24, 2010 Member Contributer Share Posted August 24, 2010 I have one of these things, http://www.ridermagazine.com/output.cfm?id=1524097 Works well and relatively inexpensive. Link to comment Share on other sites More sharing options...
Member Contributer Burns Posted August 24, 2010 Member Contributer Share Posted August 24, 2010 I have one of these things, http://www.ridermagazine.com/output.cfm?id=1524097 Works well and relatively inexpensive. I have the carbtune II.. works like a champ! Link to comment Share on other sites More sharing options...
Member Contributer YoshiHNS Posted August 24, 2010 Member Contributer Share Posted August 24, 2010 For $15 you can make your own. Very happy with mine. Link to comment Share on other sites More sharing options...
Chaz06i Posted August 24, 2010 Share Posted August 24, 2010 I have one of these things, http://www.ridermagazine.com/output.cfm?id=1524097 Works well and relatively inexpensive. I have the Carbtune II as well! It works like a champ on the VFR and the V-Twins that I own. Highly recommended! :cheerleader: Link to comment Share on other sites More sharing options...
Member Contributer spaceman Posted August 24, 2010 Member Contributer Share Posted August 24, 2010 Any sources here in the states? Link to comment Share on other sites More sharing options...
Member Contributer Burns Posted August 24, 2010 Member Contributer Share Posted August 24, 2010 Any sources here in the states? Not that I found...(unless something's changed).. ordered mine direct, and it really wasn't much of a problem, and arrived fairly quickly, as I remember. Link to comment Share on other sites More sharing options...
Chaz06i Posted August 24, 2010 Share Posted August 24, 2010 Any sources here in the states? I couldn't find anything either. I order direct from then a few months ago and got it with-in 2 weeks. Link to comment Share on other sites More sharing options...
Beck Posted August 24, 2010 Share Posted August 24, 2010 I had the old style carb balancer with the plastic tubes and mercury. Used it quite a bit when I was servicing my Hawk GT and my brother's Nighthawk 750 in the 90's, but never really tried it on my 4th gen as access to the carbs and adjusters are just not that easy. Most manufacturers have since phased out the mercury systems as nobody really wants to deal with that stuff. I noticed they use alcohol in balacers now which might work OK but I think the Mercury provided some weight/damping in the system that must result in more stable/accurate readings. beck 95 VFR Link to comment Share on other sites More sharing options...
Member Contributer FJ12Ryder Posted August 25, 2010 Member Contributer Share Posted August 25, 2010 I have one of these things, http://www.ridermagazine.com/output.cfm?id=1524097 Works well and relatively inexpensive. :fing02: I have the carbtune II.. works like a champ! +2 Link to comment Share on other sites More sharing options...
