Member Contributer y2kvfr Posted September 16, 2008 Member Contributer Share Posted September 16, 2008 So, I'm eagerly awaiting the 6th trailer (of 6) to arrive at my lot. It crashed about 2 weeks ago when an 18 wheeler crossed the centerline and ripped the box off of the trailer. Anyway, the garage is partially under the house. My truck doesn't fit, so the VFR will have a nice open space to live (mini van does fit in the other bay) What process should I use... naw scratch that. What epoxy should I use to glue the inserts into the floor for mounting the HF tire changer? What inserts do I use, and where do I get them? House progress pictures. The house gets craned together tomorrow, I'll try to update the pictures tomorrow night, so you can watch the house being put together. I'm SOOOO excited to have a nice garage floor for the VFR again. (OBTW: I'm putting in a pool too, so I need to build a pool/tool shed. WOOOHOOO). -t Link to comment Share on other sites More sharing options...
Member Contributer Rice Posted September 16, 2008 Member Contributer Share Posted September 16, 2008 Does it have to be attached? If the answer is yes, then I would drill some studs into the floor and do it that way. P.S. Building the house is something my wifea nd i would like to do one day. You must be super excited. Enjoy :rolleyes: Link to comment Share on other sites More sharing options...
Tightwad Posted September 16, 2008 Share Posted September 16, 2008 I drilled holes in the floor of my garage, and used inserts so that I can remove the Tire Changer when not in use, which is 99% of the time. This leaves 4 holes with a sleeve in them, but doesn't cause any problems. I bought the anchors at Lowes to allow this. Link to comment Share on other sites More sharing options...
Member Contributer y2kvfr Posted September 16, 2008 Author Member Contributer Share Posted September 16, 2008 I drilled holes in the floor of my garage, and used inserts so that I can remove the Tire Changer when not in use, which is 99% of the time. This leaves 4 holes with a sleeve in them, but doesn't cause any problems. I bought the anchors at Lowes to allow this. What size sleeves did you use? I imagine home desperate has them also. Any epoxy? -t Link to comment Share on other sites More sharing options...
Member Contributer johne Posted September 16, 2008 Member Contributer Share Posted September 16, 2008 I used concrete anchors.....drill holes with a masonry bit and pound em in. :rolleyes: Link to comment Share on other sites More sharing options...
Member Contributer dude Posted September 16, 2008 Member Contributer Share Posted September 16, 2008 What? No video? :rolleyes: I used concrete anchors.....drill holes with a masonry bit and pound em in. :biggrin: Link to comment Share on other sites More sharing options...
Member Contributer dutchinterceptor Posted September 16, 2008 Member Contributer Share Posted September 16, 2008 I'd recommend using a drop in anchor as shown in THIS VIDEO. Link to comment Share on other sites More sharing options...
Tightwad Posted March 21, 2009 Share Posted March 21, 2009 I'd recommend using a drop in anchor as shown in THIS VIDEO. Ohhh, I like it. The Lowes ones I used did not work very well....I have to fight them every time. I might invest in this version....not that I need 50 of them! Link to comment Share on other sites More sharing options...
