Guest thetallstewy Posted June 14, 2008 Share Posted June 14, 2008 Hey guys, i have an 85 vf100r, and i hit my electric starter just like any other day, saw smoke, turned my bike off, waited for it to stop smoking (1 min), and now my headlight is out. My guess is that it burnt the headlight wire connecting to electric starter switch? Let me know if you have any ideas Link to comment Share on other sites More sharing options...
VFR4Lee Posted June 14, 2008 Share Posted June 14, 2008 Or the bulb or fuse? You'll have to take a look see. Link to comment Share on other sites More sharing options...
Guest Posted June 14, 2008 Share Posted June 14, 2008 im pretty sure its the wiring....the wiring is 23 years old and the smoke even smelt like an electrical burn the smoke literally looked like it was coming out of the starter i know its not the bulb, because the light turned off then turned back on, but now its off completely....theres a small percentage its the fuse Link to comment Share on other sites More sharing options...
SEBSPEED Posted June 14, 2008 Share Posted June 14, 2008 Doesn't the starter circuit kill the headlight while you crank, to get maximum juice to the starter? It sounds like your starter brushes are toast. There are a few R guys here who really know their stuff, if you add "vf1000r problem" to your subject line of your topic(by using the edit button), you will get more help from the right people. :mad: Link to comment Share on other sites More sharing options...
Member Contributer jeremy556 Posted June 14, 2008 Member Contributer Share Posted June 14, 2008 Oh $%^&, you let the magic smoke out. You are going to need one of these: Check your fuses first of all. If something is shorting out and burning up, hopefully there was a fuse somewhere on that circuit. Link to comment Share on other sites More sharing options...
Member Contributer JamieDaugherty Posted June 14, 2008 Member Contributer Share Posted June 14, 2008 I agree with Seb, your starter circuit is likely the problem area. I'd look at the starter switch too. My guess, and that's all it is at this point, is that your starter is screwed up which caused excessive current through the starter button. Now the button is messed up and won't let the headlight come on. It's a chain reaction thing. It looks like you'll need to do some digging. Good luck and let us know what you find out. Link to comment Share on other sites More sharing options...
Guest Posted June 14, 2008 Share Posted June 14, 2008 fuses are fine, theres actually a 15 in place of a 10, so i gotta change that soon...but looks like ill be taking apart the electric starter area. ill give an update soon Link to comment Share on other sites More sharing options...
Member Contributer JamieDaugherty Posted June 16, 2008 Member Contributer Share Posted June 16, 2008 fuses are fine, theres actually a 15 in place of a 10, so i gotta change that soon...but looks like ill be taking apart the electric starter area. ill give an update soon I'd check the switch first, it's easier to inspect. Link to comment Share on other sites More sharing options...
Guest Posted June 18, 2008 Share Posted June 18, 2008 Well i got the headlight to work without taking apart anything. What i have to do is just tap the electric starter switch and it turns back on. Tapping it will also turn it off (if its on). Loose wire/burnt wire maybe? Eventually Ill open it up if the light permanently doesn't come on. Also, the other day, I was holding in the clutch (coming to a stop), and my bike turned off. It did it three times, but hasnt done it since (ive been doing engine breaking instead). So i think it is possibly shorting the kill switch, but dont know if the clutch has anything to do with it. Link to comment Share on other sites More sharing options...
SEBSPEED Posted June 18, 2008 Share Posted June 18, 2008 Why not do it now, since you know what the problem is??? Link to comment Share on other sites More sharing options...
