Guest Hoverboy26 Posted June 11, 2008 Share Posted June 11, 2008 Hello, I am new to the forum, I live in Phoenix, AZ. I just got a 2003 VFR800 with about 13k on it. It needs tires, and one fork is leaking oil, so i will be doing a rebuild. What fork oil does anyone recommend? Weight, brand, oil height, etc? I can change dirt bike forks in my sleep, but as I have no seat time on this bike, I could use an experienced opinion. Great forum, and I hope I can get involved. :fing02: Thanks. Link to comment Share on other sites More sharing options...
AB-Oz Posted June 11, 2008 Share Posted June 11, 2008 try some Motul 7.5wt oil, but reduce the air gap by 10mm, if you dont like the feel after setting up the static sags and riding around for a bit, its a simple job to pop the tops off the forks and syringe say 5ml out of each, then try it on the road again. Link to comment Share on other sites More sharing options...
Member Contributer jeremy556 Posted June 11, 2008 Member Contributer Share Posted June 11, 2008 Put some correct rate springs in while you are at it :fing02: Link to comment Share on other sites More sharing options...
Guest Posted June 11, 2008 Share Posted June 11, 2008 Put some correct rate springs in while you are at it :fing02: :fing02: And some Gold valves from Race Tech. Link to comment Share on other sites More sharing options...
Guest Posted July 4, 2008 Share Posted July 4, 2008 try some Motul 7.5wt oil, but reduce the air gap by 10mm, if you dont like the feel after setting up the static sags and riding around for a bit, its a simple job to pop the tops off the forks and syringe say 5ml out of each, then try it on the road again. I cheated. I took the forks off the bike, bought the seals and Motul 7.5 wt fork oil, then had a local shop do the dirty work. He set it up close to your recommendation, but reduced the gap by 5mm. I have put 800 miles on the bike after the rebuild, and it is right on the money! I may go a few clicks out on the rebound. Thanks for the info!! I am doing a 600 mile round trip this weekend, I will get it just how I like on the trip. New tires(well, 200 mles on them), full tank of gas........I'm ready to go. :blink: Link to comment Share on other sites More sharing options...
Guest Posted July 6, 2008 Share Posted July 6, 2008 A few clicks out on the rebound? What kind of forks do you have on your '03 VFR? Link to comment Share on other sites More sharing options...
spud786 Posted July 6, 2008 Share Posted July 6, 2008 try some Motul 7.5wt oil, but reduce the air gap by 10mm, if you dont like the feel after setting up the static sags and riding around for a bit, its a simple job to pop the tops off the forks and syringe say 5ml out of each, then try it on the road again. I cheated. I took the forks off the bike, bought the seals and Motul 7.5 wt fork oil, then had a local shop do the dirty work. He set it up close to your recommendation, but reduced the gap by 5mm. I have put 800 miles on the bike after the rebuild, and it is right on the money! I may go a few clicks out on the rebound. Thanks for the info!! I am doing a 600 mile round trip this weekend, I will get it just how I like on the trip. New tires(well, 200 mles on them), full tank of gas........I'm ready to go. :laugh: right on the money, what do you feel changed? you went to a lighter weight oil with less air gap, I would assume this made a little quicker fork. But hows the bottoming If you pop a wheelie , does it slam down or land cushy like a marshmellow? Link to comment Share on other sites More sharing options...
ShayneJack Posted July 6, 2008 Share Posted July 6, 2008 try some Motul 7.5wt oil, but reduce the air gap by 10mm, if you dont like the feel after setting up the static sags and riding around for a bit, its a simple job to pop the tops off the forks and syringe say 5ml out of each, then try it on the road again. I cheated. I took the forks off the bike, bought the seals and Motul 7.5 wt fork oil, then had a local shop do the dirty work. He set it up close to your recommendation, but reduced the gap by 5mm. I have put 800 miles on the bike after the rebuild, and it is right on the money! I may go a few clicks out on the rebound. Thanks for the info!! I am doing a 600 mile round trip this weekend, I will get it just how I like on the trip. New tires(well, 200 mles on them), full tank of gas........I'm ready to go. :laugh: right on the money, what do you feel changed? you went to a lighter weight oil with less air gap, I would assume this made a little quicker fork. But hows the bottoming If you pop a wheelie , does it slam down or land cushy like a marshmellow? fork oil won't change the way the bike lands after a wheelie, the brisk release of the throttle would cause a very hard landing, whereas a gradually let off would result in a feather-like touchdown. Unless of course you're on a twistie switchback, at which case it's best to keep the front planted, but if it does come up, quick shifting into 3rd should also result in a feather-pillow landing as well. But if you're on a decreasing-radius 8% downgrade left-camber apex on a four-lane road, chances are good any throttle manipulation will still result in a bone-jarring front tire contact. Leave the wheelies to the squids... :goofy: :idea3: :blink: Link to comment Share on other sites More sharing options...
spud786 Posted July 6, 2008 Share Posted July 6, 2008 oil wont effect they way the bike lands after a wheeie, Pardon me, but what planet are you from, Oil height has a big effect at the bottom of the stroke Link to comment Share on other sites More sharing options...
Guest Posted July 8, 2008 Share Posted July 8, 2008 But I still ask the question, why is RaceTech fork oil $29.95/qt? Is it made from melted down plutonium or something? I don't pay that much for my wife's aftershave I get her at Christmas. Link to comment Share on other sites More sharing options...
RustyA Posted July 28, 2008 Share Posted July 28, 2008 The question I have is, the manaul recommended fork fluid is Pro Honda Suspension SS-8. What weight is that? I have always used Maxima fork fluid. So would be nice to know if that "SS-8" is the same as 7.5 wt. or what. Link to comment Share on other sites More sharing options...
