Member Contributer Smola67 Posted October 8, 2007 Member Contributer Share Posted October 8, 2007 Have a set of 6th gen Pazzo levers coming from Ebay. Anyone know if they will fit a 5th gen? Link to comment Share on other sites More sharing options...
Member Contributer Motor_Ref Posted October 8, 2007 Member Contributer Share Posted October 8, 2007 Have a set of 6th gen Pazzo levers coming from Ebay. Anyone know if they will fit a 5th gen? When I tried to find part numbers or some way to figure this out, the information wasn't easy to find. IIRC, the brake side fits. Clutch side doesn't. Let us know what you find out. Link to comment Share on other sites More sharing options...
Member Contributer sirimiri Posted October 8, 2007 Member Contributer Share Posted October 8, 2007 Look at the Honda microfiche and see how different the levers are from the 5th to 6th gen. If the part numbers match, you're fine. Or, look up the specifications on Pazzo's site. They'll probably tell you there as well. Link to comment Share on other sites More sharing options...
Member Contributer redmarque Posted October 8, 2007 Member Contributer Share Posted October 8, 2007 Have a set of 6th gen Pazzo levers coming from Ebay. Anyone know if they will fit a 5th gen? When I tried to find part numbers or some way to figure this out, the information wasn't easy to find. IIRC, the brake side fits. Clutch side doesn't. Let us know what you find out. I've a pair of new pazzo's on order for my 98 5th Gen. (98-01) They are definatly different from the 6th gen. (02-07) :unsure: Link to comment Share on other sites More sharing options...
Member Contributer Smola67 Posted October 8, 2007 Author Member Contributer Share Posted October 8, 2007 Well if I am unable to modify them to fit I may have to sell em and keep on looking for a 5th gen set. Link to comment Share on other sites More sharing options...
Alaskan Posted October 8, 2007 Share Posted October 8, 2007 PM me if you want to sell them. Link to comment Share on other sites More sharing options...
mellowyellow Posted October 9, 2007 Share Posted October 9, 2007 Have a set of 6th gen Pazzo levers coming from Ebay. Anyone know if they will fit a 5th gen? front brake lever is differnt 5th to 6th gen, 5th gen has a little cup on the lever that presses in the master cylinder where as the 6th gen bikes do not. I had to replace my front brake master with one off a 6th gen to fit my crg levers. Link to comment Share on other sites More sharing options...
Member Contributer Smola67 Posted October 9, 2007 Author Member Contributer Share Posted October 9, 2007 Have a set of 6th gen Pazzo levers coming from Ebay. Anyone know if they will fit a 5th gen? front brake lever is differnt 5th to 6th gen, 5th gen has a little cup on the lever that presses in the master cylinder where as the 6th gen bikes do not. I had to replace my front brake master with one off a 6th gen to fit my crg levers. Thanks for the reply. Looks like I may be in the market for a used master if I am unable to modify the pazzo's Link to comment Share on other sites More sharing options...
AB-Oz Posted October 9, 2007 Share Posted October 9, 2007 G'day Smola, Talk to Mike at CTSMoto, ask nicely and he may swap the brake block over for you. He swapped my 5th gen brake block over for a CBR600rr one when I did my frankenviffer mod last year, all I had to do was pay shipping and that was it! The 5th gen brake block is unique to that model, other Honda ones are interchangeable. Link to comment Share on other sites More sharing options...
Member Contributer Smola67 Posted October 9, 2007 Author Member Contributer Share Posted October 9, 2007 G'day Smola, Talk to Mike at CTSMoto, ask nicely and he may swap the brake block over for you. He swapped my 5th gen brake block over for a CBR600rr one when I did my frankenviffer mod last year, all I had to do was pay shipping and that was it! The 5th gen brake block is unique to that model, other Honda ones are interchangeable. Sounds good. Do you have any contact info for mike. If this does not work out I am going to try and find a 6th gen master. Link to comment Share on other sites More sharing options...
AB-Oz Posted October 9, 2007 Share Posted October 9, 2007 sure mate! Linky Link to comment Share on other sites More sharing options...
mellowyellow Posted October 9, 2007 Share Posted October 9, 2007 I found a used master on ebay and thats the route I went. Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted October 9, 2007 Share Posted October 9, 2007 I found a used master on ebay and thats the route I went. What is the difference, if any, between the bore diameters? I know the 6th gen linked brake system is significantly different than the 5th gen. Link to comment Share on other sites More sharing options...
mellowyellow Posted October 9, 2007 Share Posted October 9, 2007 I found a used master on ebay and thats the route I went. What is the difference, if any, between the bore diameters? I know the 6th gen linked brake system is significantly different than the 5th gen. I never checked ,it worked with the crg lever that I purchased, it bolted up I installed it then bleed it and it has been working fine since. Link to comment Share on other sites More sharing options...
Member Contributer Smola67 Posted October 9, 2007 Author Member Contributer Share Posted October 9, 2007 Does anyone know if any other honda master will work? Link to comment Share on other sites More sharing options...
Member Contributer redmarque Posted October 9, 2007 Member Contributer Share Posted October 9, 2007 Does anyone know if any other honda master will work? Might be worth looking at a blackbird XX as they had the same linked brake system? Link to comment Share on other sites More sharing options...
Member Contributer Smola67 Posted October 17, 2007 Author Member Contributer Share Posted October 17, 2007 G'day Smola, Talk to Mike at CTSMoto, ask nicely and he may swap the brake block over for you. He swapped my 5th gen brake block over for a CBR600rr one when I did my frankenviffer mod last year, all I had to do was pay shipping and that was it! The 5th gen brake block is unique to that model, other Honda ones are interchangeable. So after getting the levers of course the brake lever does not fit. Called Mike at CTSMoto and he is going to swap the block out with only the cost of shipping. Thanks so much AB-Oz. Smola Link to comment Share on other sites More sharing options...
AB-Oz Posted October 18, 2007 Share Posted October 18, 2007 You're welcome mate, glad I was able to help. Mike at CTSMoto is a great guy, dont mind putting more business his way. Link to comment Share on other sites More sharing options...
Question
Smola67
17 answers to this question
