Member Contributer DanLegg Posted April 17, 2023 Member Contributer Share Posted April 17, 2023 I want to remove the drive sprocket cover to check for wear. I attempted to remove the slave cylinder without disconnecting the clutch hose as described in the service manual 12-7. Due to the lack of slack in the clutch hose I cannot pull the cylinder out far enough to get the clutch activation rod clear. Is the rod attached to the cylinder or should it pull free of it? I don't see anything in the manual about this. Obviously I could disconnect the clutch hose but don't want to if possible. Link to comment Share on other sites More sharing options...
Member Contributer bmart Posted April 17, 2023 Member Contributer Share Posted April 17, 2023 Smarter people will answer, but I suspect the rod/shaft is just stuck to the slave. Did you try to wiggle it loose? Link to comment Share on other sites More sharing options...
Member Contributer Captain 80s Posted April 17, 2023 Member Contributer Share Posted April 17, 2023 Yeah, just grab the rod by your fingers and manipulate them both a bit. It should pop right out. Link to comment Share on other sites More sharing options...
Member Contributer DanLegg Posted April 17, 2023 Author Member Contributer Share Posted April 17, 2023 1 hour ago, bmart said: Smarter people will answer, but I suspect the rod/shaft is just stuck to the slave. Did you try to wiggle it loose? I tried a bit on the gentle side and stopped in case I was going to screw something up. Thanks. Link to comment Share on other sites More sharing options...
Member Contributer DanLegg Posted April 17, 2023 Author Member Contributer Share Posted April 17, 2023 21 minutes ago, Captain 80s said: Yeah, just grab the rod by your fingers and manipulate them both a bit. It should pop right out. I will do that. Thanks for the help. Link to comment Share on other sites More sharing options...
Member Contributer Terry Posted April 17, 2023 Member Contributer Share Posted April 17, 2023 The rod end just pushes into a seal on the back side of the slave piston IIRC. Probably a wee bit of corrosion sticking it in place, but it should yank off without too much of a fight. Link to comment Share on other sites More sharing options...
