DesertKyorugi Posted January 25, 2022 Share Posted January 25, 2022 Not a newbie to carbs, just never had the pleasure of dealing with all plastic body floats. So, do you try to level the floats and take your 9mm measurement? Or don't level and take the 9mm measurement at the highest float? If leveling the floats, what/how is the procedure? Heat? How do we know it is going to stay level after? Thanks Link to comment Share on other sites More sharing options...
Member Contributer bmart Posted January 25, 2022 Member Contributer Share Posted January 25, 2022 I don't often get into my carbs, but when I have to set them, I use a Heisenberg compensator. (Sorry...bad Star Trek reference!) Link to comment Share on other sites More sharing options...
Member Contributer Terry Posted January 25, 2022 Member Contributer Share Posted January 25, 2022 I think there's always going to be some slight difference between the sides as the float valve is offset and the pin has a little slop so one side hangs a fraction lower than the other. Cleverer people than I use an old credit card and cut the necessary 9mm rectangle out leaving a bridge that will sit across both floats at once. Or you can use a perfessional gauge like the one picured below. Link to comment Share on other sites More sharing options...
DesertKyorugi Posted January 25, 2022 Author Share Posted January 25, 2022 17 minutes ago, Terry said: I think there's always going to be some slight difference between the sides as the float valve is offset and the pin has a little slop so one side hangs a fraction lower than the other. Cleverer people than I use an old credit card and cut the necessary 9mm rectangle out leaving a bridge that will sit across both floats at once. Or you can use a perfessional gauge like the one picured below. So....if we are going by the special gauge, it is going to measure the 9mm from the highest float. I guess that is what I will do, don't try to bend and level the floats. Just make sure the highest float is at 9mm 🤞 Link to comment Share on other sites More sharing options...
squirrelman Posted January 25, 2022 Share Posted January 25, 2022 i am no cleverer than our terry, but i make float level gauges for different bikes......... Link to comment Share on other sites More sharing options...
Member Contributer Terry Posted January 25, 2022 Member Contributer Share Posted January 25, 2022 1 hour ago, squirrelman said: i an no cleverer than our terry, but i make float level gauges for different bikes......... Way too humble Squirrelman... I learned that one from you. Link to comment Share on other sites More sharing options...
