Member Contributer weee06 Posted January 13, 2018 Member Contributer Share Posted January 13, 2018 So I am going to install the exhaust soon. Is it necessary to use the silicon in the joints? Seems like it would get all scrapped off when you install the pipe since they are a close fit. Also that makes it a problem with taking out or installing the baffle later, not to mention it needs to be removed when removing the rear tire. Link to comment Share on other sites More sharing options...
Member Contributer fink Posted January 13, 2018 Member Contributer Share Posted January 13, 2018 Have never ever used silicone. Normally use a blob of grease smeared round. Link to comment Share on other sites More sharing options...
Killerkingdon Posted January 15, 2018 Share Posted January 15, 2018 If you buy the Delk - it comes with RTV or gasket sealant. Here is the my link to the unboxing - https://youtu.be/wjeuTeLbEhc Link to comment Share on other sites More sharing options...
VFRUNNER Posted February 6, 2018 Share Posted February 6, 2018 On 15/01/2018 at 12:22 PM, Killerkingdon said: If you buy the Delk - it comes with RTV or gasket sealant. Here is the my link to the unboxing - https://youtu.be/wjeuTeLbEhc Nice video . Do a great job with it . Link to comment Share on other sites More sharing options...
Killerkingdon22 Posted February 6, 2018 Share Posted February 6, 2018 Thanks - Link to comment Share on other sites More sharing options...
Member Contributer Grum Posted February 7, 2018 Member Contributer Share Posted February 7, 2018 On 16 January 2018 at 4:22 AM, Killerkingdon said: If you buy the Delk - it comes with RTV or gasket sealant. Here is the my link to the unboxing - https://youtu.be/wjeuTeLbEhc Hi Kiiller. Bike and pipe look GREAT. But no point in using the RTV on both joints, you will be removing the pipe from the cat junction to remove your wheel. Cheers. Link to comment Share on other sites More sharing options...
Member Contributer VFROZ Posted February 7, 2018 Member Contributer Share Posted February 7, 2018 The RVT sealer supplied by Delkevic doesn’t stick like normal silicone. If you don’t use it on the downpipes, it will leak. I’ve redone mine because of my bad method. You don’t use a lot, and you place it on the intside of the outer tube, it will spread as you fit the inner tube. Link to comment Share on other sites More sharing options...
Member Contributer weee06 Posted February 10, 2018 Author Member Contributer Share Posted February 10, 2018 I ended up using some on the female parts just past the slots. I let it set over night. I didn’t hear any leaks. Link to comment Share on other sites More sharing options...
Member Contributer VFROZ Posted February 11, 2018 Member Contributer Share Posted February 11, 2018 By the way, I never use it on the muffler, I use hot temp anti sieze instead. Makes it easy to remove it later. Link to comment Share on other sites More sharing options...
