otmaximus Posted January 15, 2020 Posted January 15, 2020 I have a 5G wheel mounted on my 97 so I could run a more common 180 tire. My 94 still has the original wheel with a 170 tire. Does anyone run a 180 tire on the original width 4G wheel? paul in SoCal Quote
Member Contributer ducnut Posted January 15, 2020 Member Contributer Posted January 15, 2020 I wouldn’t, as it crowns the tire, affecting the footprint. Manufacturers design tires around specific rim widths, so you’re best to stick with a 170 on the 5” rim. Plenty of 5th Gen wheels around to swap, though. Quote
Member Contributer SamW Posted January 16, 2020 Member Contributer Posted January 16, 2020 Or 3rd Gen wheel, even though the 3rd Gen ran a 170 tire, it is a 5.5" vs. 5" of the 4th Gen. 1 Quote
Member Contributer MBrane Posted January 16, 2020 Member Contributer Posted January 16, 2020 It depends on the tire. I've run 180 Pilot Road on a stock 4th gen without issue. Pilot Power would be a different story due to the more elliptical profile. I doubt it would be a serious issue, but the handling would be different for sure. Just something to be aware of. Quote
otmaximus Posted January 17, 2020 Author Posted January 17, 2020 Thanks for the feedback. I can definitely tell the difference between the 180 and the 170. I ran a Shinko 170 once and it was way wider than a normal 170. I figure a 180 must have a similar profile to that Shinko. just wasn’t sure if the integrity of the wider tire mounted on the stock rim would be affected. cant be much more variable than a worn tire or under-inflated tire. paul in SoCal Quote
otmaximus Posted January 17, 2020 Author Posted January 17, 2020 On 1/15/2020 at 4:22 PM, SamW said: Or 3rd Gen wheel, even though the 3rd Gen ran a 170 tire, it is a 5.5" vs. 5" of the 4th Gen. If I could find a 3G wheel that would be the way to go. 5G is more available on eBay. But it’s a pain notching out the center of the wheel to match the 4G hub. Quote
coldsoda Posted January 21, 2020 Posted January 21, 2020 I found it well worth fitting the 5gen wheel to the 4th gen. running michelin road 5 tires (180 rear) and the bike handles great. really pleased with the setup. 3 Quote
Member Contributer ducnut Posted January 21, 2020 Member Contributer Posted January 21, 2020 Better looking wheel, too. Quote
bikemoto Posted March 19, 2020 Posted March 19, 2020 You could try a 170 adventure spec tyre, e.g. Michelin Road 5 Trail, but they do have a different construction optimised for a softly-suspended, higher c-of-g adventure bike. No idea if it is better or worse than squeezing a normal 180 on the 5.00" rim. So far, there are still enough 170s around to keep me happy. My next tyre is likely the Pirelli Angel GT2. Keen to compare it to the Dunlop Roadsmart III currently in use. Quote
Member Contributer YoshiHNS Posted March 20, 2020 Member Contributer Posted March 20, 2020 https://www.sportbiketrackgear.com/pirelli-diablo-rosso-ii-rear-tires/ Quote
