Ian01 Posted August 23, 2017 Share Posted August 23, 2017 I just installed some helibars- put everything back together, and now some of the controls don't work. It starts and the headlights work... the turn signals, hazards and horn do not work. Many ideas? Could have blown a fuse or something ? Thanks guys Link to comment Share on other sites More sharing options...
Member Contributer Grum Posted August 23, 2017 Member Contributer Share Posted August 23, 2017 Fuse B 10amp. Controls Turn Signals, Horn and Brake Light. Link to comment Share on other sites More sharing options...
Ian01 Posted August 23, 2017 Author Share Posted August 23, 2017 Thanks - I figured it must be a fuse - I'll have to check in AM.... could simply taking halves apart on controls cause a fuse to blow? Seems strange Link to comment Share on other sites More sharing options...
Member Contributer Terry Posted August 23, 2017 Member Contributer Share Posted August 23, 2017 Might pay to check the brake light switch, it can be rotated far enough that the terminals can touch the metal bar and cause a short that would take out a fuse. Link to comment Share on other sites More sharing options...
Member Contributer fink Posted August 23, 2017 Member Contributer Share Posted August 23, 2017 Replied on FB Link to comment Share on other sites More sharing options...
Ian01 Posted August 23, 2017 Author Share Posted August 23, 2017 6 hours ago, Terry said: Might pay to check the brake light switch, it can be rotated far enough that the terminals can touch the metal bar and cause a short that would take out a fuse. I hope that's it - the switch was loose and flopping around during the install Link to comment Share on other sites More sharing options...
Ian01 Posted August 23, 2017 Author Share Posted August 23, 2017 Weird - brake lights work, ignition works, brights work but no hazard, turn signals or horn Link to comment Share on other sites More sharing options...
Member Contributer Terry Posted August 23, 2017 Member Contributer Share Posted August 23, 2017 Maybe check the connector for the left bar switch pod and makes sure it hasn't been partly pulled apart during the Heli install. Link to comment Share on other sites More sharing options...
Member Contributer fink Posted August 23, 2017 Member Contributer Share Posted August 23, 2017 My next thought. Link to comment Share on other sites More sharing options...
Ian01 Posted August 23, 2017 Author Share Posted August 23, 2017 I'm on my way to buy a 10 amp fuse... I see one located in the compartment (in front of the front brake lever) blew Link to comment Share on other sites More sharing options...
Ian01 Posted August 23, 2017 Author Share Posted August 23, 2017 I replaced the fuse and the turn signals started working again. When I slid the emergency lights switch, the fuse blew. Since I never used emergency lights before, I'm not sure if it was problematic before my helibars. Anyways, I don't plan to ever use the emergency lights-so.... Link to comment Share on other sites More sharing options...
Auspanglish Posted August 24, 2017 Share Posted August 24, 2017 You have a wire shorting out somewhere in that area Link to comment Share on other sites More sharing options...
