bigmalcy Posted September 22, 2015 Share Posted September 22, 2015 Hi guys (and gals?) Hopefully a simple question: I want to remove the seat pad from the rear seat cowl on my 3rd gen. I thought it would come off after removing the screw but it seems pretty tight on there. Is there a nack to removing it? There are two black plugs and it looks like the trick might be to squeeze them while pressing them out at the same time. Can anyone confirm? Doesn't seem to want to budge and don't want to break anything... Malcolm Link to comment Share on other sites More sharing options...
Member Contributer gll429 Posted September 22, 2015 Member Contributer Share Posted September 22, 2015 to remove the seat on your bike you need to unlock it with your key.and then press a lever on the lock. if you are referring to a plastic "solo seat" cover. its bolted on . one bolt on each side of the seat . carefully slide up. Link to comment Share on other sites More sharing options...
keny Posted September 22, 2015 Share Posted September 22, 2015 I belive its the solo seat covers "pad" he refers to, hope this helps: Link to comment Share on other sites More sharing options...
Member Contributer RC51Nick Posted September 22, 2015 Member Contributer Share Posted September 22, 2015 I've replaced one before. You have to unlock 2 plastic push pin tangs on the pad after removing the screw. A small screw driver with a little pressure does the trick. Nick Link to comment Share on other sites More sharing options...
bigmalcy Posted September 23, 2015 Author Share Posted September 23, 2015 Thanks guys - successfully removed with a bit of pressure and squeezing on the plastic tangs... bit embarrassed to have asked such a simple question... must be getting lazy in my old age! Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted September 23, 2015 Member Contributer Share Posted September 23, 2015 Better to ask then to break..... Link to comment Share on other sites More sharing options...
Csanad Posted February 10, 2016 Share Posted February 10, 2016 Hey guys, i want to buy a seat cowl for my 93` VFR750, I`ve found one but the color of the pad is grey, my seat is black. Is it possible to paint it black, it is plastic or leather? (i only saw it on pictures) thanx Link to comment Share on other sites More sharing options...
Member Contributer gll429 Posted February 10, 2016 Member Contributer Share Posted February 10, 2016 its the same fabric as your seat .. recover both with 15 bucks of vinyl of your choice . Link to comment Share on other sites More sharing options...
Csanad Posted February 10, 2016 Share Posted February 10, 2016 Thanks! Link to comment Share on other sites More sharing options...
bigmalcy Posted February 12, 2016 Author Share Posted February 12, 2016 I actually changed the colour of mine using VHT Vinyl Dye... not sure if it is available worldwide, but did a good job... It worked on the seat, too, so it is pretty tough stuff. Link to comment Share on other sites More sharing options...
