trchidester1 Posted August 27, 2015 Share Posted August 27, 2015 Has anyone ever needed to adjust the seat latch cable? I find mine has a lot of slack, to the point of barely clearing the latch when actuated, and I don't see an adjustment in the service manual diagrams. Thanks! Link to comment Share on other sites More sharing options...
Member Contributer Cogswell Posted August 27, 2015 Member Contributer Share Posted August 27, 2015 There is no cable adjustment on 6th gens. It could be that the cable end has come out of the locating boss on either end. Checking the key end would require battery removal. Link to comment Share on other sites More sharing options...
Member Contributer Egg on Leggs Posted August 27, 2015 Member Contributer Share Posted August 27, 2015 Has anyone ever needed to adjust the seat latch cable? I find mine has a lot of slack, to the point of barely clearing the latch when actuated, and I don't see an adjustment in the service manual diagrams. Thanks! Change the cable, do it now. The reason it is getting longer is because it is breaking slowly as Bowden cables do. Link to comment Share on other sites More sharing options...
Lint Posted August 29, 2015 Share Posted August 29, 2015 Has anyone ever needed to adjust the seat latch cable? I find mine has a lot of slack, to the point of barely clearing the latch when actuated, and I don't see an adjustment in the service manual diagrams. Thanks! Change the cable, do it now. The reason it is getting longer is because it is breaking slowly as Bowden cables do. Yeah, that would just suck. Link to comment Share on other sites More sharing options...
Member Contributer Egg on Leggs Posted August 29, 2015 Member Contributer Share Posted August 29, 2015 If it does break it is not the end of the world. A friend had one break and I was able to replace it. Link to comment Share on other sites More sharing options...
Beck Posted August 29, 2015 Share Posted August 29, 2015 I think the problem could be that if it breaks, it will be hard to remove the saddle if you cannot find/ reach the end of the cable to pull at it..... Link to comment Share on other sites More sharing options...
Member Contributer Egg on Leggs Posted August 29, 2015 Member Contributer Share Posted August 29, 2015 The way to do it. You will need a suitable sized bit to fit the Allen screws under the saddle and a 6mm spanner to turn it. By prising up the edge of the saddle you can fit the bit into the screw, a long nosed pliers will help. Releasing the saddle means it presses down on the bit, holding it in position. Undo the screws each side. If you have pillion grips or pannier frames fitted, these will have to come off. With the external screws removed from the saddle surround it is now possible to ease the surround rearwards enough to get to the seat latch mechanism. Link to comment Share on other sites More sharing options...
