house Posted October 24, 2014 Share Posted October 24, 2014 I decided to replace the bulbs with LED versions while I wait on more products to be released for the 8th Gen and/or more ideas to him me. This was a fairly simple deal, but you will need 6 Ohm load resistors to keep the blinker speed in check. I used Putco Plasma LED bulbs based on the reviews I read and the guarantee. Just pull the cover off the taillight, unscrew the two bolts that hold the rear taillight assembly in place, swap the bulbs and install the load resistors. I put mine under the wires that feed each bulb and just slit the cover of the factory wire sheath and tapped the wires with positaps. As you can see, they are noticeably brighter Next up was the SW-Motech rear rack with the Givi Monokey plate for my luggage. I really like this rack and waited weeks for it to arrive. The only downside is that it has no grab handles.... which I didn't mind. It is heavy though... I feel like all the weight I lost with the Akrapovich pipe was just bolted back on :) I got mine at Twisted Throttle since SW-Motech won't ship to the US directly to customers. It is a well made rack and looks great. Check out the blocking plate to keep whatever out of your underseat space It has metal spacers to keep the fairing in place, nice touch! This shot shows the clearance over the taillight With a Givi T459 Attached.... and a photobomb Without any luggage Link to comment Share on other sites More sharing options...
NZCam Posted February 23, 2015 Share Posted February 23, 2015 I'm interested to know if you've had any issues with your LED load resistors and heat dissipation? No melted plastic anywhere? Did you consider swapping the turn-signal flasher relay rather than fitting load resistors? Link to comment Share on other sites More sharing options...
house Posted March 16, 2015 Author Share Posted March 16, 2015 I am not sure these resistors are working correctly.... I ride year-round and the blinkers flash quickly when it's very cold. If it's above freezing, no issues. Looking for alternates to see if they make a difference. No heat issues so far Link to comment Share on other sites More sharing options...
NZCam Posted March 16, 2015 Share Posted March 16, 2015 On 17/03/2015 at 6:19 AM, house said: I am not sure these resistors are working correctly.... I ride year-round and the blinkers flash quickly when it's very cold. If it's above freezing, no issues. Looking for alternates to see if they make a difference. No heat issues so far Just cold, or wet (very moist air counts as wet)? If there's a short across your load resistors (attached in parallel I assume?), that would explain the intermittent fast-flashing. A short could be caused by something as simple as water beading across exposed wiring (dashed line in the diagram below). I would check the insulation around your load resistor wire-taps, maybe add some extra heat-shrink. Link to comment Share on other sites More sharing options...
Member Contributer Cogswell Posted March 16, 2015 Member Contributer Share Posted March 16, 2015 Without any luggage The Akrapovic really looks great on the 8th gen. Could I ask where you obtained the front wheel chock? It looks like it could pull double duty in a trailer as well as the garage. Link to comment Share on other sites More sharing options...
house Posted March 17, 2015 Author Share Posted March 17, 2015 Without any luggage The Akrapovic really looks great on the 8th gen. Could I ask where you obtained the front wheel chock? It looks like it could pull double duty in a trailer as well as the garage. They are from WheelDock and work great on a trailer. They have brackets to secure them to the trailer (or you could use anchors and secure the bracket to the garage floor if you wanted.) I don't use brackets in the garage as the WheelDock pretty much stays put. I've had them for a few years now and really like them. You just drive in and step on the release to lock your bike into the chock. http://www.wheeldock.com/ Here's the brackets... http://www.wheeldock.com/store/item/quick-detach-transport-bar I also really like these for the rear tie-down mounts http://www.wheeldock.com/store/item/stealth-plates-pair http://www.wheeldock.com/store/item/tie-down-kit-pair The stealth plates allow you to pull the tie-down mounts in case you need to have a flat surface on your trailer, but still have the bolt mounts in place for later use without having to crawl under the trailer to re-mount. I am not sure these resistors are working correctly.... I ride year-round and the blinkers flash quickly when it's very cold. If it's above freezing, no issues. Looking for alternates to see if they make a difference. No heat issues so far Just cold, or wet (very moist air counts as wet)? If there's a short across your load resistors (attached in parallel I assume?), that would explain the intermittent fast-flashing. A short could be caused by something as simple as water beading across exposed wiring (dashed line in the diagram below). I would check the insulation around your load resistor wire-taps, maybe add some extra heat-shrink. Resistor_wiring_diagram.png Definately just when cold... been caught in the rain a few times and had no issues. Now that the temps are above freezing, no issues. I used Positaps, so switching out the resistors should be quick (they are a little buried, but no more than 15 min to swap them out.) Link to comment Share on other sites More sharing options...
Allyance Posted March 17, 2015 Share Posted March 17, 2015 If resistors were receiving voltage constantly, then heat might be a problem, but for the short time they are on, they shouldn't get hot. E squared/resistance=power, 12x12/6=24 watts, what rating did you use for resistors? Link to comment Share on other sites More sharing options...
NZCam Posted March 27, 2015 Share Posted March 27, 2015 House, did you install LEDs just in the tail, or did you do your front indicators too? I'm having a bugger of a time figuring out how to squeeze load resistors into the mirror housings. I've got the 2-inch long 6ohm resistors. If you've done this mod, I'd love a quick photo? Link to comment Share on other sites More sharing options...
Auspanglish Posted March 27, 2015 Share Posted March 27, 2015 I thought the 8th gen already came w LEDs all round Link to comment Share on other sites More sharing options...
DriverDave Posted March 27, 2015 Share Posted March 27, 2015 Not the turn signals. Link to comment Share on other sites More sharing options...
