Member Contributer Dutchy Posted August 27, 2014 Member Contributer Share Posted August 27, 2014 I started to notice that my clutch was getting a bit noisier, ticking increasing with revs. And once last week I felt the clutch slip (once). I just took Sebs clear cover of, took out the springs and measured them. They are well within specifications. Puts the springs in agian and here is where I made an error. I misread the manual and after turning the bolts that go in the springs in (by hand) strated torquing the first bolt with 22Nm This the reference number, the torque value is 12Nm OOPS! As I approached the 22Nm value on my torque wrech I heard a "crack". This led me to re-examin the manual and discover my error. Took the bolts out and remeasured the spring, it was still as before so in spec. tighten all the bolts to 12nm, refitted the cover. Now... The clutch lever could be pulled in completely and after 2 pumps firmed up. BUT I cannot pull the clutch in Put the gearbox in neutral (had it in 1st gear to prevent rolling of the sidestand) Started the engine and killed the engini right away. It sounds horrible. Rattling VERY loudly. I *suspect* but what do I know a cracked clutch friction plate... I will now have to pull the entire cover off (have spare set clutch plates and gasket. but in the mean time, your diagnosis and advise is much appreciated..... Link to comment Share on other sites More sharing options...
mcrwt644 Posted August 27, 2014 Share Posted August 27, 2014 I had the same issue with my one fourth gen and the handle. It turned out to be air at the master cylinder. I couldn't budge it. As for the noise, I'd probably go in and pull the entire clutch to see what you find and certainly change the oil afterwards Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted August 27, 2014 Author Member Contributer Share Posted August 27, 2014 Duh....I had only removed the clear clutch cover and did not (nor could) see if the plates were fitted between the legs...Och well, I can now check the thickness of the plates... :-) Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted August 27, 2014 Author Member Contributer Share Posted August 27, 2014 Game over But I have a spare :-) Link to comment Share on other sites More sharing options...
raoufhakam Posted August 27, 2014 Share Posted August 27, 2014 Started the engine and killed the engini right away. It sounds horrible. Rattling VERY loudly. now you have a Ducati you seem to have a spare of everything -which is always a good thing- i have a spare key for my bike, thats about all the spare parts i have Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted August 27, 2014 Author Member Contributer Share Posted August 27, 2014 Clutch friction plates are still good The inner clutch basket though has some significant? grooves My spare clutch has grooves too but not as significant.. I feel a winter project coning up.... Unless what you see makes you tell me to stop riding the rest of the summer. Link to comment Share on other sites More sharing options...
The Phantom Posted August 27, 2014 Share Posted August 27, 2014 Wow, lucky for you. The clutch basket itself is a big dollar item, so check it carefully while you have it all apart. Give the tangs a sand if they are showing any signs of deformation. The clutch basket is the same part number from 1986 to 1997, for anyone who may need to track one down. Leon you'll get away with sanding the tangs back, that wear is not 'significant'. Link to comment Share on other sites More sharing options...
raoufhakam Posted August 27, 2014 Share Posted August 27, 2014 i've seen much worse wearing marks on clutch baskets than that, on my old 1980 Honda Goldwing GL1100 project that i had couple of years ago, but it was 34 years old with 80k on it and clutch was still running fine. im no expert, but i would assume these wear marks should be no problem Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted August 27, 2014 Author Member Contributer Share Posted August 27, 2014 Wow, lucky for you. The clutch basket itself is a big dollar item, so check it carefully while you have it all apart. Give the tangs a sand if they are showing any signs of deformation. The clutch basket is the same part number from 1986 to 1997, for anyone who may need to track one down. Leon you'll get away with sanding the tangs back, that wear is not 'significant'. Cheers Phantom and rauouf! Bought a spare clutch assembly (baskets, bearing, clutch plates, metal plates) for the pressure plate. So I could paint that and have it ready for when Seb's cover would arrive. Paid 50 euro's which I now realise was a steal..... (sold the friction+metal plates on for 25 euro) AND the spare pressure plate now comes in VERRy handy Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted August 27, 2014 Author Member Contributer Share Posted August 27, 2014 new plate in, problem solved. The plates were all around 2.8-2.9mm so that is not bad at 87,000km Link to comment Share on other sites More sharing options...
keny Posted August 27, 2014 Share Posted August 27, 2014 Good you got it sorted out, I have to take a look at my clutch also next winter, I suspect I have wraped metall plates......Noisy and a lot of vibrations when leting the clutch out at higher revs Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted August 28, 2014 Author Member Contributer Share Posted August 28, 2014 Well, I reckon my redslut's holes are getting a bit worn..... Have always used a torque wrench to button up the clutch cover (12Nm), but one bolt still stripped the thread in the casing :-( Rumaged in the box of bolts and found a longer allen bolt that did the trick. Could not find a proper sized small diameter O ring. But she took 12Nm so fingers crossed.... Never a dull moment with my redslut!!! :-) Link to comment Share on other sites More sharing options...
