klrtovfr 35 Posted August 1, 2014 Share Posted August 1, 2014 (edited) I just picked up a Power Commander V. If anyone has the following mods especially for the catless header could you please send or upload your map, I would greatly appreciate it. I only see them posted for 06-09. 2002-2005 6th gen 99 catless headers fully gutted stock mufflers with 1.5" rear exit holes BMC Air Filter DEsnorkeled/flapper removed pair Valves/Evap Canister Stock Velocity Stacks tall rear, short front Edited August 1, 2014 by klrtovfr Quote Link to post Share on other sites
zRoYz 121 Posted August 1, 2014 Share Posted August 1, 2014 I have uploaded a map you can try from my 04 file name vfr800doin It is a PC3 map but can load to PCV as I now use a PCV, it was dyno map. I use Motad headers so close to same as catless 99 All my other mods are same except my mufflers are LEO 1 Quote Link to post Share on other sites
klrtovfr 35 Posted August 1, 2014 Author Share Posted August 1, 2014 alright I will give that a try. Thank you. I just needed something until I can make it to the dyno probably in september. Im sure the gutted stock vs leo isnt going to make a huge difference. Quote Link to post Share on other sites
Member Contributer jim v 37 Posted August 1, 2014 Member Contributer Share Posted August 1, 2014 I hate to thread jack but a question for folks running a PCV on 02-05's - How hard was it to make that combination work? I have an 02 with PC3 and would like to try a PCV but, supposedly, they only work with 06-09 models. Quote Link to post Share on other sites
klrtovfr 35 Posted August 2, 2014 Author Share Posted August 2, 2014 Havent got mine hooked up yet but it will work. I think you were mislead as they work on 02-09 and possibly on 5th gens as well. They usually come with a map designed for an 06-09 but you can load an 02-05 map on there. 06-09 can use the map for each gear as that is the way it is from the factory but I am unsure if it works on 02 yet. Quote Link to post Share on other sites
zRoYz 121 Posted August 2, 2014 Share Posted August 2, 2014 PCV will work fine on any vtec, power commander don't list it for models under 09 because that was PCV release date. I have a PCV on my 04 (originally had PC3) you can even use the PC3 map which is compatible with the PCV. The maps however aren't backwards compatible you can't use a PCV map on a PC3. So in other words if you want to try the PC3 maps made for the 02-05 you can as they will load onto the PCV. Quote Link to post Share on other sites
Baileyrock 837 Posted August 2, 2014 Share Posted August 2, 2014 Isn't Tinyminds Map still in our downloads or was he using a PC3? Quote Link to post Share on other sites
klrtovfr 35 Posted August 3, 2014 Author Share Posted August 3, 2014 ya I see that his does fueling in 500 rpm increments where the others are done in 250 rpm increments. Quote Link to post Share on other sites
Member Contributer rhoderage 64 Posted August 3, 2014 Member Contributer Share Posted August 3, 2014 I just installed my PCV last week on my 02 and its great, no issues for the 02-05's even though Dynojet doesn't "officially" support them. I used member GPM's fuel map as he ran a similar stock setup to myself. Quote Link to post Share on other sites
klrtovfr 35 Posted August 13, 2014 Author Share Posted August 13, 2014 Cozyes map felt exactly like stock powerwise but quite a bit smoother. Tinyminds map is ridiculous at vtec engagement, makes me lose concentration. However, coasting at 7200rpm then to wot it feels like a lot more torque compared to stock/cozyes. I get a lot of backfiring on downshifts with tinyminds also. I definitely need to get it tuned hopefully after my next track day. Quote Link to post Share on other sites
