MorganR715 Posted May 20, 2014 Share Posted May 20, 2014 So were in the final stretch of getting my bike ready for paint, but as I was looking through schematics of the gas tank I realized there were some cushions missing. I ordered the missing ones through partzilla, along with the trim pieces(currently there is a split fuel hose someone else put on as a makeshift trim) I was originally looking for. So does anyone have any idea where these things go? Is there any way someone might be able to post a picture with the factory locations? Here's mine, exactly how we pulled it off(minus fuel hose trim) Link to comment Share on other sites More sharing options...
Member Contributer V-FORE Posted May 20, 2014 Member Contributer Share Posted May 20, 2014 So were in the final stretch of getting my bike ready for paint, but as I was looking through schematics of the gas tank I realized there were some cushions missing. I ordered the missing ones through partzilla, along with the trim pieces(currently there is a split fuel hose someone else put on as a makeshift trim) I was originally looking for. So does anyone have any idea where these things go? Is there any way someone might be able to post a picture with the factory locations? Here's mine, exactly how we pulled it off(minus fuel hose trim) Looking at the picture right side middle looks like a "T" the little rubber donuts go on the end of the t and slide into the opening under the steering head, see part #23 in the link http://www.motosport.com/motorcycle/oem-parts/HONDA/1993/VFR750F/FUEL-TANK-90_93 I was able to find Rubber washers at lowes, so I did not have to wait for the correct ones. Hope that helps Link to comment Share on other sites More sharing options...
V4 Rosso Posted May 20, 2014 Share Posted May 20, 2014 When you look close you can still see where they were before. But here is a pic of a spare with only one of the rubbers missing. HTH. Link to comment Share on other sites More sharing options...
MorganR715 Posted May 20, 2014 Author Share Posted May 20, 2014 Thanks guys, this is exactly what I needed. If you look at that schematic, number 18, tank trim B, I'm not sure where that would go. Other than that, I'm good! Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted May 21, 2014 Member Contributer Share Posted May 21, 2014 The black rubber thingies you better glue to the tank. upon lifting the tank they tend to fall off; with bad luck somewhere between the cilinder blocks... Also, on the opposite side of the T piece with the grommets, there is this long bolt affixing the tank to the frame. There is an inner sleeve (In V4 Rosso's picture you can see it it just sticking out at the bottom); if this is not perfectly centered, you will not be able to get the tank on (or off) Link to comment Share on other sites More sharing options...
V4 Rosso Posted May 21, 2014 Share Posted May 21, 2014 #18 tank trim B go here: Link to comment Share on other sites More sharing options...
MorganR715 Posted May 21, 2014 Author Share Posted May 21, 2014 Thanks again, guys! Yeah, that sleeve is no longer being made, apparently. They called it a collar, but I cant really find it. I'll keep looking. Thanks for the tip, and thanks for circling the spots for me Link to comment Share on other sites More sharing options...
V4 Rosso Posted May 22, 2014 Share Posted May 22, 2014 Maybe you can get a similar looking and sized piece of rubber to stick on the side of the tank, as long as it protects the tank from touching the frame you are OK. Here some pics so you know what to look for: The orignal rubber is about one and a quarter inch in length. This is how it is attached to the tank. Link to comment Share on other sites More sharing options...
MorganR715 Posted May 22, 2014 Author Share Posted May 22, 2014 Awesome pictures, thank you! But I already have those purchased, the only piece I couldnt get was the rubber collar that slides into the hole for bolting to the frame. Also, that #18 piece actually isn't those spots you circled, those are #22. Wondering what the #18 piece is going to wind up being. Ill post pics when i get them in! Link to comment Share on other sites More sharing options...
Member Contributer JZH Posted May 22, 2014 Member Contributer Share Posted May 22, 2014 If you search the part number 17518-MT4-300 in Google Images, there's a pic at: http://www.ddmototeam.com/pieces/images/10727_photo.JPE CMS also shows a set of the rubber parts, but unfortunately not in situ: Ciao, Link to comment Share on other sites More sharing options...
