Member Contributer gll429 Posted August 25, 2014 Member Contributer Share Posted August 25, 2014 no need. just pull the plug and tap it out to the next size up. . no big deal at all!! just put a lot of grease on the pat to trap all the shavings. Yes, this will be my first line of repair. Will be pulling the pan this week and take a look at drilling & tapping next size up. Not too crazy about drilling and tapping upside down, in limited space, with the added bonus of possible shavings in the oil pan. dude.. put the bike on the center stand and use grease on the tap. you only save yourself an hour or so.. this is a tried and true simple repair. dont beleive me? tap a bolt anywhere.. your bicycle water bottle bolt. go from 5mm to 6mm. put grease all over the tap and be shocked when you pull it out Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted August 25, 2014 Member Contributer Share Posted August 25, 2014 Pulling the pan is a pain in the butt, gll429 is right .... Link to comment Share on other sites More sharing options...
wera803 Posted August 25, 2014 Share Posted August 25, 2014 Get a Fumoto valve in the next size up and install that after you fix the hole. No more having to remove that plug and strip it again. Link to comment Share on other sites More sharing options...
Member Contributer B4V4 Posted August 25, 2014 Author Member Contributer Share Posted August 25, 2014 put the bike on the center stand and use grease on the tap. you only save yourself an hour or so.. this is a tried and true simple repair. dont beleive me? tap a bolt anywhere.. your bicycle water bottle bolt. go from 5mm to 6mm. put grease all over the tap and be shocked when you pull it out Yes, the more I read, the more I realize that tapping is definitely the way to go. I image finding a shoulder bolt & crush washer that size should be my next order of business. However, I do want to take the pipes off anyway. Looking a little speckled so wouldn't mind shooting some exhaust paint on them. Figured this is as good a time as any. Link to comment Share on other sites More sharing options...
Member Contributer B4V4 Posted August 26, 2014 Author Member Contributer Share Posted August 26, 2014 Pulling the pan is a pain in the butt, gll429 is right .... Not so much. Pulled the exhaust off in about 45 mins, 30 of which was trying to get at the silly square-nut off the right pedal assembly so I could get at the rear exhaust joint. The rest was a breeze. Now to find a shoulder bolt and tap the sucker. Pic of the troublesome bolt off my previous (and spotless) 99. Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted August 26, 2014 Member Contributer Share Posted August 26, 2014 Pulling the pan is a pain in the butt, gll429 is right .... Not so much. Pulled the exhaust off in about 45 mins, 30 of which was trying to get at the silly square-nut off the right pedal assembly so I could get at the rear exhaust joint. The rest was a breeze. Now to find a shoulder bolt and tap the sucker. Pic of the troublesome bolt off my previous (and spotless) 99. BrakePedal.png There are sealed with type of black Permatex sealer. Link to comment Share on other sites More sharing options...
