artee Posted June 23, 2013 Share Posted June 23, 2013 Hi Recently finished my wheel conversion on my vfr700 but found that the cbr600 forks are a little too short. I have used 1988-89 vfr750 triples as they use the41mm fork size required. Is there any way to either.... Extend the forks, keeping the compression and preload intact or.. Use a set of stepped top triple clamps from another model. Roger Link to comment Share on other sites More sharing options...
timmythecop Posted June 23, 2013 Share Posted June 23, 2013 did you try sliding the tubes down to flush with the top triple and using aftermarket clip-ons? either way, it has been done Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted June 23, 2013 Share Posted June 23, 2013 I had custom fork caps made out of stainless steel that were identical in every respect to the stock ones, only longer. The seam between the fork leg and the fork cap where they screw together was held fast in the upper triple clamp, so the whole joint was clamped (after tightening the fork cap) which made me feel secure that it would not fail. Sorry, I have no pictures, the bike has been long since sold. Link to comment Share on other sites More sharing options...
Member Contributer Kel Posted June 23, 2013 Member Contributer Share Posted June 23, 2013 did you try sliding the tubes down to flush with the top triple and using aftermarket clip-ons? +1 Slide the forks down and use some adjustable clipons( or taller ones from a different bike) under the top triple. Don't run it like it is, looks like it will hit the rad. Link to comment Share on other sites More sharing options...
artee Posted June 24, 2013 Author Share Posted June 24, 2013 Good call on the clipons, never thought of that. I am running the bike with no problems, it does not hit the radiator. I have had to use stiffer springs though. I have gone up to .95 Thank so far Roger did you try sliding the tubes down to flush with the top triple and using aftermarket clip-ons? either way, it has been done Where did you get my picture from?Roger Link to comment Share on other sites More sharing options...
Member Contributer Switchblade Posted June 24, 2013 Member Contributer Share Posted June 24, 2013 This picture ? Link to comment Share on other sites More sharing options...
timmythecop Posted June 24, 2013 Share Posted June 24, 2013 well I am not called timmythecop because I am a bartender. that fugly fender looks familliar Link to comment Share on other sites More sharing options...
artee Posted June 24, 2013 Author Share Posted June 24, 2013 Yeah that pick. This is the before pic. I have posted it on several sites, but never seen anyone else use it. Where can I find clip ons with that sort of rise? Can't find any on this side of the pond. Roger Link to comment Share on other sites More sharing options...
timmythecop Posted June 24, 2013 Share Posted June 24, 2013 http://www.ebay.co.uk/itm/Adjustable-CNC-Clip-On-Handlebar-41mm-Silver-HD10-/230762022417?pt=UK_Motorcycle_Parts&hash=item35ba7d0611 Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted June 24, 2013 Share Posted June 24, 2013 Convertibars??? Gilles Variobars??? Both options more spendy than the DanMoto offering. Link to comment Share on other sites More sharing options...
artee Posted June 24, 2013 Author Share Posted June 24, 2013 Hi Seen those. Actually looking at the moment. Those are cheaper from Danmoto direct @ $69. Not sure how much rise I will need without a few measurements. I have also thought of going down the superbike handlebar road. I now need to curb the spending a little so I wont be jumping straight in and buying anything at the moment. Thanks for all the help chaps. Roger Link to comment Share on other sites More sharing options...
