JWhelan65 Posted March 25, 2013 Share Posted March 25, 2013 So I bought braided lines from cyclebrakes.com and the front brake line banjos are turned the opposite direction. Does anyone have another source? 2 lines? or 3 with a splitter? Link to comment Share on other sites More sharing options...
smackdoogle Posted March 25, 2013 Share Posted March 25, 2013 Go through HEL. That's who I got my SS braided lines for my VFKR when I had it. I initially went with Galfer they were like yours, wouldn't fit. I called Galfer and they fixed the problem and gave me a free brake line. Link to comment Share on other sites More sharing options...
Member Contributer gll429 Posted March 25, 2013 Member Contributer Share Posted March 25, 2013 go to any harley shop and get some goodrich "sniper 2" fittings and custom make your own lines. the tubing is 1/3 the diameter of n"normal ' lines and are 10,000 psi rated you get it in black or braided all you need.. 4 working brain cells. 8 , 10 and 12 mm wrenchs a good set of sharp diagonal cutters. new brake fluid and your drink of choice Link to comment Share on other sites More sharing options...
Member Contributer unbalanced Posted March 25, 2013 Member Contributer Share Posted March 25, 2013 I got all mine from Spiegler, http://www.spieglerusa.com/brakes/cycle-brake-line-kits.html You can rotate the banjos... Link to comment Share on other sites More sharing options...
JWhelan65 Posted April 17, 2013 Author Share Posted April 17, 2013 I think I figured it out Link to comment Share on other sites More sharing options...
Grilldemon Posted May 4, 2013 Share Posted May 4, 2013 I got all mine from Spiegler, http://www.spieglerusa.com/brakes/cycle-brake-line-kits.html You can rotate the banjos... I too, went to Spiegler. 2-line kit for the front. Rotated the banjos, don't forget the longer banjo bolt, and they fit awesome. Red ends with smoke lines. Link to comment Share on other sites More sharing options...
Member Contributer Captain 80s Posted May 4, 2013 Member Contributer Share Posted May 4, 2013 Depending on how you have the bars adjusted, a double banjo at the master cylinder can come very close and even hit the gauges with steering at full left. Just something to look for at installation. Link to comment Share on other sites More sharing options...
Guest Posted May 5, 2013 Share Posted May 5, 2013 I recently bought some Venhill brake lines from the UK, great fit, it's a two line kit but they have three line with a splitter if you prefer. Great quality, great fit and they look fantastic. Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted May 5, 2013 Share Posted May 5, 2013 I recently bought some Venhill brake lines from the UK, great fit, it's a two line kit but they have three line with a splitter if you prefer. Great quality, great fit and they look fantastic. I got Venhill domed allen head banjo bolts, and while I found them to be quite attractive, they are rather soft as well. I stripped one of the allen heads with a 3/8" drive allen bit using a 3/8" torque wrench, set to the recommended value in the FSM. I want to say they were 5mm drive, but I forget at the moment. Link to comment Share on other sites More sharing options...
JWhelan65 Posted May 8, 2013 Author Share Posted May 8, 2013 I think I figured this out, but yet the double banjo is an issue Link to comment Share on other sites More sharing options...
