Guest ArizonaRC36 Posted August 17, 2012 Share Posted August 17, 2012 Last few weeks, when starting up the VFR for the first time before a ride, been hearing progressively louder ticking... then more into slight "rattle" sound. Now today just seems much louder "rattle" sounds. A bit more on the right side of the bike... somewhere mid to upper part near the carb/cyclinder areas. Not 100% sure of the exact location, but left side is not as bad sounding per say. Last few days, coming back from a ride, the sounds weren't as noticeable as when the bike is first started up after sitting and is completely cooled down. I had my buddy pick up the bike today to bring to his shop, until I can get to it. I am really worried, he mentioned that it could be a "spun main bearing"... ??????? Or possibly, though unlikely... the oil pump let go. I've never heard or had a bike that had a spun main bearing. Could this be the case? Bike has appx 30,000 miles, never had valve adjustments done yet, oil changed every 2500 mi and no other opperating issues until now. Any help would be welcomed. Link to comment Share on other sites More sharing options...
Member Contributer gll429 Posted August 17, 2012 Member Contributer Share Posted August 17, 2012 1st up remove the side panels and remove the gas tank.. place i tank a on crate on table close by..and run a long gas line to the fuel pump.. remove the airbox... .. now..check ALL the freaking bolts around and on the motor.. all tight? run the bike.. and listen for the noise..and pray... if you have a mechanic stethoscope that would be great.. if not.. a long screw driver with a solid handle works OK. ( as far as i remember anyway.. deaf now! ) hopefully your hearing loose bolts if not... now remember.. this is a gear driven model.. there are gears in the middle of the motor that COULD be loose.. really freaking rare.. but Possible that the gear train spindle got blown. keep us updated. Link to comment Share on other sites More sharing options...
Member Contributer Lorne Posted August 17, 2012 Member Contributer Share Posted August 17, 2012 Fourth gen VFRs had a TSB related to customer noise complaints. Link: http://s628.photobucket.com/albums/uu5/imaginationman2003/?action=view¤t=385_vfrcam5B15D.jpg Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted August 17, 2012 Member Contributer Share Posted August 17, 2012 before you start drilling....... Mine sometimes has a ticking noise, sometime it doesnot. If you can record a small video/sound, we can tell you if we recognise it. mine has 70k km, never been opened, the engine doesnot get an easy low rev life.............. a used engine costs around 300 bucks. here so no point in spending money on undressing her and drilling a hole.... Link to comment Share on other sites More sharing options...
Member Contributer gll429 Posted August 17, 2012 Member Contributer Share Posted August 17, 2012 a used engine costs around 300 bucks. here so no point in spending money on undressing her and drilling a hole.... spending money? its a do it yourself project...he is in AZ home of the biggest motorcycle yard on earth. Link to comment Share on other sites More sharing options...
