BluRoad Posted May 23, 2012 Share Posted May 23, 2012 I had a front brake binding on my '90 VFR project, cleaned, inspected, lubed, reinstalled... the pads still bind. So, I removed the really sticky pistons and seals, ruining one piston in the process. No worries, just give a call to my local aftermarket shop -- oops, no piston/seal kits available? What? I've rebuilt second generation calipers in the past so I assumed that kits would be available for the newer models too. So, anyone know of a source? I see ebay has a seller in England with kits but a disclaimer that they may fit other market bikes, but he only warrants that they will fit the UK models. Anyone? JOE in WI Link to comment Share on other sites More sharing options...
Member Contributer YoshiHNS Posted May 23, 2012 Member Contributer Share Posted May 23, 2012 can't get them from service honda? Link to comment Share on other sites More sharing options...
BluRoad Posted May 24, 2012 Author Share Posted May 24, 2012 Haven't checked on the availability, but the price is $120+ for one caliper. Ouch. So I'm looking for aftermarket which is typically half the price. Link to comment Share on other sites More sharing options...
Member Contributer YoshiHNS Posted May 24, 2012 Member Contributer Share Posted May 24, 2012 No idea then. Just hope that whatever aftermarket stuff you find is decent. Apparently aftermarket fork seals can't hold a candle to honda OEM. Link to comment Share on other sites More sharing options...
Veefer800Canuck Posted May 24, 2012 Share Posted May 24, 2012 The caliper piston seals should be common to a shit ton of Hondas. I know the rear ones in my 800 fit XR's and the like. Get on Ronayers.com. check the part numbers and plug them into the "where does this part fit" and you will probably come up with a bunch of listings, so if they fit a wide array of Hondas that are newer than your '90, you should stand a good chance of having them available still. Link to comment Share on other sites More sharing options...
Guest Posted May 29, 2012 Share Posted May 29, 2012 not sure if you found seals yet but I just completely rebuild both front calipers with parts from Ronayers.com. All of the piston seals and even the little rubber boots that the calipers slide on were available. Throw in some M8 x 1.25 by 24mm speed bleeders and you're golden! Funny, now that I've rebuilt the calipers, forks, and put on steel braided lines, I've decided to go CBR 954 front end on my 93. can't wait! Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted May 29, 2012 Member Contributer Share Posted May 29, 2012 http://www.thurn-motorsport.de/html/bremsen-rc36.html Link to comment Share on other sites More sharing options...
