1986 Wheels on a 1998
filterfool
Not without a huge load of surgery, axle diameters, bearings, spacers, discs wrong diameter and spacing, etc.
And then you've taken a 25 year leap backwards in tire/wheel sizing.
18x3.5 rear, 16x2.5 front versus 17x5.5 rear and 17x3.5 front.
130/80-18 bias ply rear vs 180/55-17 radial rear
110/90-16 bias front vs 120/70-17 radial front.
It ain't worth it even if the wheels are free and you own your own machine shop.
Now going the OTHER way would be great, but the SSSA is notoriously difficult to adapt to a 2nd gen. As in cutting the frame and welding.
Even at that, you may get the chain to align, but good luck with the wheel centerlines, or vice versa.
Okay guys, thanks :rolleyes: I had a chance to get a good deal on some white wheels and was only thinking of the nice color combination it would make. I didn't consider the mechanical difficulties until you knowledgeble folks spoke up.
Thanks for the good advice.
filterfool
Lazy :schla15:
A lot less work than swapping wheels from another bike.
Removing the rear wheel is a piece of cake. Getting the tire off the rim, let the dealer do that. Done.
Removing the front wheel = another piece of cake. Remove brake rotors, easy-peasy. Driving the wheel bearings out is the only hard part of the job.
