Guest bradc Posted November 17, 2008 Share Posted November 17, 2008 OK new question where is a good place to buy stainless brake lines for our vfr's? has anyone done this or upgraded there brakes to like Brembo or something else? Is it possible to upgrade? Link to comment Share on other sites More sharing options...
SEBSPEED Posted November 17, 2008 Share Posted November 17, 2008 You have a '94, so it will be easier & cheaper for you to get them than for a 5th or 6th gen owner. Yo ucan make your own or do some searching to find a supplier, sorry, I don't know of one off the top of my head. You can try emailing companies like Goodridge, Russel, Galfer and Spiegler. Link to comment Share on other sites More sharing options...
Tightwad Posted November 17, 2008 Share Posted November 17, 2008 Pretty sure this has been covered, but are they actually braided lines, or simple metal braid covered rubber/plastic lines? I liked the swingarm setup Seb helped do, but was curious what the line was made of, and if it was brake fluid grade line, or simply fuel line. Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted November 17, 2008 Member Contributer Share Posted November 17, 2008 I got Goodridge ones on my 4th Gen I like the "over the fender look"you can also have two lines runing down from the top they come in fact in various colours. PS: I had a few cups of coffee while the bike mechanic fitted them, so donot ask how hard it was to put them on Link to comment Share on other sites More sharing options...
SEBSPEED Posted November 17, 2008 Share Posted November 17, 2008 Pretty sure this has been covered, but are they actually braided lines, or simple metal braid covered rubber/plastic lines? I liked the swingarm setup Seb helped do, but was curious what the line was made of, and if it was brake fluid grade line, or simply fuel line. They are semi-hard inside, it's a teflon material covered with the stainless braid. Definitely stiffer than stock. Link to comment Share on other sites More sharing options...
Question
Guest bradc
OK new question
4 answers to this question
