Member Contributer Ryanme17 Posted August 17, 2008 Member Contributer Share Posted August 17, 2008 And if so, where do I get them? Anyone have them? You like them? Is the bulb hard to find in orange? Link to comment Share on other sites More sharing options...
SEBSPEED Posted August 17, 2008 Share Posted August 17, 2008 Just order the lens from a 2006 or newer VFR, and swap with yours. They clip on. If you have trouble finding the orange bulbs, there is a special spray paint available at most auto parts stores made for tinting bulbs. Link to comment Share on other sites More sharing options...
Member Contributer alwaysaware Posted August 17, 2008 Member Contributer Share Posted August 17, 2008 They are stock on 08s. I'm not sure about other years. Just buy the clear LEDs that light up amber. :pissed: Link to comment Share on other sites More sharing options...
Guest Posted August 17, 2008 Share Posted August 17, 2008 I installed the 06 lenses front and rear... along with LEDs. Ordered the parts from servicehonda.com... fronts are about $25 each if I recall. Rear is expensive, about $250. For LEDs, I had to buy a new turn signal relay from customdynamics.com to keep it from blinking fast. Link to comment Share on other sites More sharing options...
Member Contributer Ryanme17 Posted August 17, 2008 Author Member Contributer Share Posted August 17, 2008 Thanks! Link to comment Share on other sites More sharing options...
Veefer Madness Posted August 17, 2008 Share Posted August 17, 2008 They are stock on 08s. I'm not sure about other years. Just buy the clear LEDs that light up amber. :squid: Since you have front running lite/signals, I have two extra sets of these. http://superlumination.com/images/auto_bul...tower2_a_wm.jpg http://superlumination.com/images/auto_bul...7whiteamber.gif The first uses load equalizers: http://superlumination.com/images/leds/load_equalizer.jpg The 'switchbacks' need a digital flashing relay: http://www.customdynamics.com/trick_flashe...ard_DOT_Flasher I don't have an extra relay, but I have the rest. :pissed: Also, check Ebay for the taillight. Not a huge chance, but I just missed out on one for $137 by $2! :squid: PM if interested. Greg :squid: Link to comment Share on other sites More sharing options...
Member Contributer Rivcyko Posted August 17, 2008 Member Contributer Share Posted August 17, 2008 And here's how to put them on. http://www.vfrdiscussion.com/forum/index.php?showtopic=31120 Link to comment Share on other sites More sharing options...
Guest Posted September 3, 2008 Share Posted September 3, 2008 All I did with mine, was take some lens paint that you can get for car tail lights. Polished them to get them good and smooth, rubbed them down with varsol to clean them. Sprayed them with the lens paint, like 4 coats I think I went (I wanted them black as black could be) them I just got a spray can of clear coat for the body shop, and sprayed them with that. Turned out a whole lot better than I ever thought they could :pissed: Link to comment Share on other sites More sharing options...
Member Contributer pres589 Posted September 3, 2008 Member Contributer Share Posted September 3, 2008 All I did with mine, was take some lens paint that you can get for car tail lights. Polished them to get them good and smooth, rubbed them down with varsol to clean them. Sprayed them with the lens paint, like 4 coats I think I went (I wanted them black as black could be) them I just got a spray can of clear coat for the body shop, and sprayed them with that.Turned out a whole lot better than I ever thought they could :pissed: This villager is demanding pictures, and a link for the mentioned lens paint, because this sounds interesting. Link to comment Share on other sites More sharing options...
Guest Posted September 4, 2008 Share Posted September 4, 2008 Now keep in mind here, the bike is slighty apart, but here is the front end http://tinypic.com/view.php?pic=bit0r9&s=4 Close up of the side http://tinypic.com/view.php?pic=29209kw&s=4 And a pic of the can of stuff I used http://tinypic.com/view.php?pic=2z7r7zq&s=4 From what I have heard, it either is or soon will be unavailable in Canada. Link to comment Share on other sites More sharing options...
Member Contributer Ryanme17 Posted September 11, 2008 Author Member Contributer Share Posted September 11, 2008 Now keep in mind here, the bike is slighty apart, but here is the front endhttp://tinypic.com/view.php?pic=bit0r9&s=4 Close up of the side http://tinypic.com/view.php?pic=29209kw&s=4 And a pic of the can of stuff I used http://tinypic.com/view.php?pic=2z7r7zq&s=4 From what I have heard, it either is or soon will be unavailable in Canada. I bet you get this a lot, but why make your bike less visible? Link to comment Share on other sites More sharing options...
SEBSPEED Posted September 11, 2008 Share Posted September 11, 2008 Cuz it's kewl. :ohmy: Link to comment Share on other sites More sharing options...
Member Contributer Alien VFR Posted September 11, 2008 Member Contributer Share Posted September 11, 2008 Now keep in mind here, the bike is slighty apart, but here is the front endhttp://tinypic.com/view.php?pic=bit0r9&s=4 Close up of the side http://tinypic.com/view.php?pic=29209kw&s=4 And a pic of the can of stuff I used http://tinypic.com/view.php?pic=2z7r7zq&s=4 From what I have heard, it either is or soon will be unavailable in Canada. I bet you get this a lot, but why make your bike less visible? Do you have any pics of the signals lit up? I'm curious how visible they really are. Personally, I like the clear lenses only on a black, white or silver VFR. I think the standard amber looks better on all other colors. Link to comment Share on other sites More sharing options...
