Guest 1LuckyDude Posted August 6, 2008 Share Posted August 6, 2008 I have a 10k mile 93 that is pretty much original. It still has the stock R/R in it with no signs of any wiring issues overheating. So that is a good sign that it's not gone bad or torched any wires yet. My question is...if I put a fan on the stock R/R, will that be enough or go ahead and get a finned R/R. Seems if I put the computer fan on it that would be better than just a finned one. But the experience here is what I am seeking. :fing02: I do plan on upgrading the wiring while I have it ripped apart for inspection/cleaning. I'm a firm believer of preventive maintenance. Link to comment Share on other sites More sharing options...
Member Contributer rctwentyfour Posted August 6, 2008 Member Contributer Share Posted August 6, 2008 Hello: No, I do not have the DIRECT experience you are seeking (on a '93, that is), but I'd argue that "the more, the merrier." That is to say, why not do both - both an R/R with the heat sink fins, AND the computer fan? Every little thing you can do helps. I added a computer fan to my OEM (Shindengen) R/R, and it seems to help. The Shindengen for my bike (an '89 FK) has the heat sink "fins." I also added a voltmeter, which I consider invaluable. It gives you an opportunity to watch the voltages while you are underway; HIGHLY RECOMMENDED. rctwentyfour Link to comment Share on other sites More sharing options...
Member Contributer Dutchy Posted August 6, 2008 Member Contributer Share Posted August 6, 2008 Hello, back in 1997 I strapped a CPU heatsink (was it Pentium II ? :fing02: ) to my 4th Gen. Never looked back since...... ymmv Link to comment Share on other sites More sharing options...
Guest Posted August 6, 2008 Share Posted August 6, 2008 I guess I am simply asking that if I can keep the original one cool, will it be OK? I will for sure get a spare to have on hand though. Link to comment Share on other sites More sharing options...
Member Contributer rctwentyfour Posted August 6, 2008 Member Contributer Share Posted August 6, 2008 I guess I am simply asking that if I can keep the original one cool, will it be OK?Hello:Yes, your question may be "simple," but the answer is not. NOBODY on this discussion group can diagnose your riding. There are a lot of variables; that is, a lot of questions: How hard/fast do you ride? How hot is the ambient temperature when you are riding? Do you often get caught up in stop-n-go traffic? How healthy is the rest of your charging system? ( a ) Stator working properly? ( b ) Connectors clean and free of corrosion? ( c ) Battery fully-charged? ( d ) Grounds solid, clean on your bike? So, maybe yes – maybe the fan alone will work for you; maybe not. If you manage to keep ANY of the R/Rs on the market cool, they will last longer. It is heat that kills 'em off. rctwentyfour Link to comment Share on other sites More sharing options...
Guest Posted August 6, 2008 Share Posted August 6, 2008 I guess I am simply asking that if I can keep the original one cool, will it be OK?Hello:Yes, your question may be "simple," but the answer is not. NOBODY on this discussion group can diagnose your riding. There are a lot of variables; that is, a lot of questions: How hard/fast do you ride? How hot is the ambient temperature when you are riding? Do you often get caught up in stop-n-go traffic? How healthy is the rest of your charging system? ( a ) Stator working properly? ( b ) Connectors clean and free of corrosion? ( c ) Battery fully-charged? ( d ) Grounds solid, clean on your bike? So, maybe yes – maybe the fan alone will work for you; maybe not. If you manage to keep ANY of the R/Rs on the market cool, they will last longer. It is heat that kills 'em off. rctwentyfour Thats' a pretty simple answer for me. I already plan on cleaning all the contacts, upgrade the wiring and such. So I'll just plan on doing a fan and getting another R/R to keep on hand. :rolleyes: Link to comment Share on other sites More sharing options...
Member Contributer Blue Viffer Posted August 6, 2008 Member Contributer Share Posted August 6, 2008 I guess I am simply asking that if I can keep the original one cool, will it be OK?Hello:Yes, your question may be "simple," but the answer is not. NOBODY on this discussion group can diagnose your riding. There are a lot of variables; that is, a lot of questions: How hard/fast do you ride? How hot is the ambient temperature when you are riding? Do you often get caught up in stop-n-go traffic? How healthy is the rest of your charging system? ( a ) Stator working properly? ( b ) Connectors clean and free of corrosion? ( c ) Battery fully-charged? ( d ) Grounds solid, clean on your bike? So, maybe yes – maybe the fan alone will work for you; maybe not. If you manage to keep ANY of the R/Rs on the market cool, they will last longer. It is heat that kills 'em off. rctwentyfour Thats' a pretty simple answer for me. I already plan on cleaning all the contacts, upgrade the wiring and such. So I'll just plan on doing a fan and getting another R/R to keep on hand. :rolleyes: Been there done that. Think you would be better off with the Gixxer RR and a fan. vince Link to comment Share on other sites More sharing options...
soichiro Posted August 6, 2008 Share Posted August 6, 2008 If it's working fine now, it wont hurt to try the fan or heat sink. If it has made it this far, I would hate to mess with it. Be prepare with a good finned one. Link to comment Share on other sites More sharing options...
Member Contributer JZH Posted August 7, 2008 Member Contributer Share Posted August 7, 2008 A PC fan blowing air onto a potted surface doesn't seem like it would have much of an effect. :laugh: There's no real evidence that it does/no real evidence that it doesn't. However, it is clear that the OEM reg/rec wasn't designed for air cooling, hence, no fins. But go ahead and do it if it makes you feel better... :fing02: Ciao, Link to comment Share on other sites More sharing options...
Member Contributer rctwentyfour Posted August 13, 2008 Member Contributer Share Posted August 13, 2008 A PC fan blowing air onto a potted surface doesn't seem like it would have much of an effect. :fing02: There's no real evidence that it does/no real evidence that it doesn't. However, it is clear that the OEM reg/rec wasn't designed for air cooling, hence, no fins. But go ahead and do it if it makes you feel better... :fing02: Ciao, Hello:Actually, the way I have the computer case fan installed is that it is drawing heat off from the R/R. To be honest, I've not ridden it enough to know with certainty that this modification will work over the long-haul (I have the bike up on stands at the moment - re-jetting the carbs). All I can report is "so far, so good." rctwentyfour Link to comment Share on other sites More sharing options...
