Guest ashai Posted February 24, 2008 Share Posted February 24, 2008 My brake lights are always on, it seems that the brake light switch, front or back is oresses regardless of handles position. anyone had the same problem? Link to comment Share on other sites More sharing options...
LDSRIDER Posted February 24, 2008 Share Posted February 24, 2008 My back switch needed adjustment when I first got the bike. Easy to do. right side of the bike at your calf. Link to comment Share on other sites More sharing options...
Member Contributer Rivcyko Posted February 24, 2008 Member Contributer Share Posted February 24, 2008 My back switch needed adjustment when I first got the bike. Easy to do. right side of the bike at your calf. Link to comment Share on other sites More sharing options...
Member Contributer sirimiri Posted February 24, 2008 Member Contributer Share Posted February 24, 2008 Make sure that your brake pads are not dragging, either just in case it isn't merely a "switch" clearance issue. Link to comment Share on other sites More sharing options...
Guest Posted February 24, 2008 Share Posted February 24, 2008 Thanks, i will check and try to adjust Link to comment Share on other sites More sharing options...
soichiro Posted February 24, 2008 Share Posted February 24, 2008 Yep probably the rear switch. Easy to adjust. Ck the wires for the front one. Link to comment Share on other sites More sharing options...
Auspanglish Posted February 24, 2008 Share Posted February 24, 2008 Happened to me. Turned out it was the rear switch mechanism, it would get stuck in the on position. I went over the bike sooo many times, as it was intermitent but slowly got worse... to the point where I blew a couple of the bulbs and the bulb-housing (socket) melted and it caused the fuse for the Turn-signals and horn to blow too!! Apparently it can be disassembled and lubricated... Link to comment Share on other sites More sharing options...
squirrelman Posted February 24, 2008 Share Posted February 24, 2008 A very common Honda electrical problem across all models using this piece. YES, the switch can be disassembled by CAREFULLY spreading the top with a small blade to allow the 2 white tabs to come out for a clean up and lube. I've bored a very small hole in the body of the unit and spray lube in periodically.....seems to work OK. Link to comment Share on other sites More sharing options...
Guest Posted February 27, 2008 Share Posted February 27, 2008 Thanks guys. i went and adjusted the rear switch, half a turn, now it's perfect. Link to comment Share on other sites More sharing options...
soichiro Posted February 27, 2008 Share Posted February 27, 2008 Thanks guys. i went and adjusted the rear switch, half a turn, now it's perfect. Glad to help. :thumbsup: I have had the same problem on my honda cruiser once. Link to comment Share on other sites More sharing options...
