Guest hougy Posted February 10, 2008 Share Posted February 10, 2008 This has happened a few times. It happens sometimes when I am rolling to a stop, when I am AT a stop and I shift my weight around a bit. It sounds like it's coming from the front end, and it sounds like someone is crunching a coke can. I looked at my forks and there is some rust where the inside fork meets the "larger" section. Any ideas what it could be?? | = "Large" fork portion : = "Inside" fork section * = Rust activity () = End of fork at the wheel ||||**:::::) Link to comment Share on other sites More sharing options...
spud786 Posted February 10, 2008 Share Posted February 10, 2008 Ya mean ya have rust in the seal area of the fork or at the dust cap? Link to comment Share on other sites More sharing options...
Member Contributer FotoMoto Posted February 10, 2008 Member Contributer Share Posted February 10, 2008 A "clunk" type of sound is usually loose or worn out steering head bearings. Not sure about a can crunching kind of sound. Link to comment Share on other sites More sharing options...
Member Contributer BusyLittleShop Posted February 10, 2008 Member Contributer Share Posted February 10, 2008 A "clunk" type of sound is usually loose or worn out steering head bearings. Not sure about a can crunching kind of sound. Bingo on the source of the clunk... Link to comment Share on other sites More sharing options...
Member Contributer jeremy556 Posted February 10, 2008 Member Contributer Share Posted February 10, 2008 The noise is probably steering bearings. Replace with some All Ballz Racing tapered rollers. While you have the forks off, pull them apart and at the very least change the oil, seals, and get the rust off with emory cloth and polish with 800+ grit sand paper. Link to comment Share on other sites More sharing options...
Guest Posted February 10, 2008 Share Posted February 10, 2008 The noise is probably steering bearings. Replace with some All Ballz Racing tapered rollers.While you have the forks off, pull them apart and at the very least change the oil, seals, and get the rust off with emory cloth and polish with 800+ grit sand paper. Sweet, Ill take a gander at it all monday. thanks! Link to comment Share on other sites More sharing options...
