Guest Posted October 27, 2007 Share Posted October 27, 2007 You can get the bushings from Honda. New dust seals come with the fork seals. Jeremy, I'm trying to figure out what I need to get from Honda. Is the bushing I need the Guide Bushing (11) or Guide Slider (12)? And is the the seal set (21) what I want? Someone said new dust seal (28) were included but it looks like those are a seperate part. So do I also need to order those also? fork diag.JPG thanks. Link to comment Share on other sites More sharing options...
SEBSPEED Posted October 27, 2007 Share Posted October 27, 2007 You can get the bushings from Honda. New dust seals come with the fork seals. Jeremy, I'm trying to figure out what I need to get from Honda. Is the bushing I need the Guide Bushing (11) or Guide Slider (12)? And is the the seal set (21) what I want? Someone said new dust seal (28) were included but it looks like those are a seperate part. So do I also need to order those also? fork diag.JPG thanks. You want parts 11 and 21. The dust seal does come with the oil seal. :thumbsup: Link to comment Share on other sites More sharing options...
Member Contributer jeremy556 Posted October 27, 2007 Member Contributer Share Posted October 27, 2007 Jeremy,I'm trying to figure out what I need to get from Honda. Is the bushing I need the Guide Bushing (11) or Guide Slider (12)? And is the the seal set (21) what I want? Someone said new dust seal (28) were included but it looks like those are a seperate part. So do I also need to order those also? thanks. You want 11, 12, and 21. 21 is the set that includes both the oil seal and dust seal. Check the link in my signature for pricing if you are planning on ordering these :salesman: Link to comment Share on other sites More sharing options...
Poncho Posted October 27, 2007 Share Posted October 27, 2007 I am 180 lbs and went with the .95. Its great, I also changed ( with a lot of help from Sebspeed, thanks again) the valving. What a big change, stiffer and smoother. BUT!!!!..... there is always a but, the back end seems even softer then before so that will have to be fixed. If you change your fork springs be ready, you might have to deal with the rear shock. Link to comment Share on other sites More sharing options...
enzed_viffer Posted October 27, 2007 Share Posted October 27, 2007 I ordered some 0.95 Sonic springs, then freaked out because even though that's what their caluclator came up with for my weight (~200 poooondz) all you guys seemed to be recommending 0.90s. Should I see if I can change the order, or will it be OK? Link to comment Share on other sites More sharing options...
Member Contributer jeremy556 Posted October 27, 2007 Member Contributer Share Posted October 27, 2007 .95 will be fine. I have .95 and am 180lbs without gear. Link to comment Share on other sites More sharing options...
enzed_viffer Posted October 28, 2007 Share Posted October 28, 2007 Thanx, Jeremy! :thumbsup: Before you replied I went back to their (Sonic Springs) site, and even when I put myself AND the VFR on a diet, it still came up as 0.95, so I guess they're OK. Link to comment Share on other sites More sharing options...
