Guest jerms Posted July 27, 2007 Share Posted July 27, 2007 So my 5th Gen has been sitting for some time with electrical gremlins, and I got around to trying to pinpoint the problem the other day. I am not mechanically inclined, but wanted to take a look around. Here's what I found... When trying to start, the solenoid will click very loudly, and randomly turn the engine over but go right back to clicking. Or it will do nothing - no lights, no instrumentation, no fuel pump. I ordered a new one from a local dealer and replaced it yesterday, but it's doing the same thing. Can anyone tell me if there is something else I can check on my own, or am I going to have to fork over the money and the headache of taking it in for service? Thanks guys. Link to comment Share on other sites More sharing options...
Member Contributer Stéphane Posted July 27, 2007 Member Contributer Share Posted July 27, 2007 So my 5th Gen has been sitting for some time with electrical gremlins, and I got around to trying to pinpoint the problem the other day. I am not mechanically inclined, but wanted to take a look around. Here's what I found...When trying to start, the solenoid will click very loudly, and randomly turn the engine over but go right back to clicking. Or it will do nothing - no lights, no instrumentation, no fuel pump. I ordered a new one from a local dealer and replaced it yesterday, but it's doing the same thing. Can anyone tell me if there is something else I can check on my own, or am I going to have to fork over the money and the headache of taking it in for service? Thanks guys. Your battery is weak. Charge it or boost it and it will turn over. Link to comment Share on other sites More sharing options...
Tightwad Posted July 27, 2007 Share Posted July 27, 2007 The other option is the ignition switch...no lights at all, but then sometimes starting would seem to point to a battery that works. The best thing to do is start by testing the battery voltage, then trying to crank the engine over while reading the voltage on the battery. If the voltage on the battery is 12+ volts, and you have no lights, you are missing a connection somewhere. If the voltage is 12+, but then drops to less than 8 when trying to crank it, your battery needs charged/replaced. Link to comment Share on other sites More sharing options...
Guest Posted July 27, 2007 Share Posted July 27, 2007 Hmm - I had just charged the battery before trying this. Maybe it's not holding a full charge. I'll check tonight. Thanks... Link to comment Share on other sites More sharing options...
Member Contributer Hagios Posted July 27, 2007 Member Contributer Share Posted July 27, 2007 Sounds like a problem that a CBR-F1 I was looking at buying a few years back had. It was the ignition switch, which is an easy fix--a little contact cleaner and a toothbrush later, everything worked great. Link to comment Share on other sites More sharing options...
Member Contributer redmarque Posted July 27, 2007 Member Contributer Share Posted July 27, 2007 I agree, sounds like not enough juice in the battery - starter relay clicks like a cockroach. Link to comment Share on other sites More sharing options...
klrtovfr Posted July 27, 2007 Share Posted July 27, 2007 check your grounds sounds like a short. Find a long thin wire and put one end in the back of the blue connector located on left side under fairing where the green wire is and the other end either to the negative terminal on the battery or to a bolt on the frame and then try starting it. Link to comment Share on other sites More sharing options...
