Guest none Posted May 28, 2007 Share Posted May 28, 2007 My VFR 6th gen clock and meter were resetting these few mornings. Bike was able to crank but cranking was a longer than usual and weak. Meter and clock reset after the weak crank. Take the battery off to charge using a battery tender. Next morning having 12.6V readout. Bike idling with no lights 13.9V Bike idling with pilot lights 13.2-13.5V Bike idling with headlights 12-12.6V Bike running at 4-5k rpm with 2 x philips 55/60w headlights 12.8-13.3V Bike running at 4-5k rpm with 2 x philips 55/60w headlights, occasional signal light and brake 11.2-11.8V Are these healthy voltages? What's causing the reset? Link to comment Share on other sites More sharing options...
Member Contributer Snafu Posted May 28, 2007 Member Contributer Share Posted May 28, 2007 How old is the battery? Link to comment Share on other sites More sharing options...
Guest Posted May 28, 2007 Share Posted May 28, 2007 YTZ14S battery is 1 year 8 months old, done 22000km only. Link to comment Share on other sites More sharing options...
Member Contributer Motor_Ref Posted May 28, 2007 Member Contributer Share Posted May 28, 2007 Bad or loose connection somewhere? Link to comment Share on other sites More sharing options...
Guest Posted May 29, 2007 Share Posted May 29, 2007 Now the FI is acting strangely. When running, the FI will show up and the engine dies. Half clutch to get the engine started again. Happens twice on a 10km journey. Link to comment Share on other sites More sharing options...
Member Contributer jeremy556 Posted May 29, 2007 Member Contributer Share Posted May 29, 2007 You have a charging issue for sure, probably R/R, connection issue, or stator. With headlights/brights on at 5500 RPM you should get 13.4-14.8 volts. There is a How-To Guide for diagnosing charging issues in the How-To Guide section of this forum. Link to comment Share on other sites More sharing options...
turtlecreek Posted May 29, 2007 Share Posted May 29, 2007 You have a charging issue for sure, probably R/R, connection issue, or stator. With headlights/brights on at 5500 RPM you should get 13.4-14.8 volts.There is a How-To Guide for diagnosing charging issues in the How-To Guide section of this forum. :goofy: voltages are definitely off....follow mr jeremy's advice. Link to comment Share on other sites More sharing options...
VFR4Lee Posted May 29, 2007 Share Posted May 29, 2007 Sounds like the Rectum Fryer. :goofy: Link to comment Share on other sites More sharing options...
Member Contributer Daniel Paul Posted May 29, 2007 Member Contributer Share Posted May 29, 2007 sounds like loose battery cables... Link to comment Share on other sites More sharing options...
