Guest MichaelR Posted May 8, 2006 Share Posted May 8, 2006 I just installed the OEM heated hand grips, and unfortunately they won't come on... at all... period... under any conditions... even if I'm at 10K RPM. They are simple enough to install, hook up into a relay, plug in the color coded connectors, and voila! Only, they're not seeming to work. Does anyone have any suggestions on troubleshooting the darn things? TIA! Michael Link to comment Share on other sites More sharing options...
Baileyrock Posted May 8, 2006 Share Posted May 8, 2006 A Volt meter to see if youe getting powere were needed! :huh: Link to comment Share on other sites More sharing options...
Guest MichaelR Posted May 9, 2006 Share Posted May 9, 2006 Any ideas what voltage I should be looking for and where I should be looking? Link to comment Share on other sites More sharing options...
Beck Posted May 9, 2006 Share Posted May 9, 2006 I just installed the OEM heated hand grips, and unfortunately they won't come on... at all... period... under any conditions... even if I'm at 10K RPM.? They are simple enough to install, hook up into a relay, plug in the color coded connectors, and voila! Only, they're not seeming to work.? Does anyone have any suggestions on troubleshooting the darn things? TIA! Michael <{POST_SNAPBACK}> Just curious, OEM? I didn't know Honda had them for VFRs, unless they could be UK market heated grips (re-labeled Oxfords?), or are they Gold Wing or ST units? Show us some shots of the grips when you have a chance. Beck 95 VFR Link to comment Share on other sites More sharing options...
Darth Bling Posted May 9, 2006 Share Posted May 9, 2006 It's could be possible the wiring harness for the US spec bikes is different than the European bikes. I know the European have a few extra things we don't have here in the US, like the flash to pass button, or the ability to turn off our headlights with the right handlebar switches. Link to comment Share on other sites More sharing options...
Guest MichaelR Posted May 10, 2006 Share Posted May 10, 2006 I'll get some pictures of them soon... I don't know about the european heated grips... these I went down to the dealer and ordered as a honda accessory. But it's a pair of grips, and a little box that mounts to the left handle bar with a knob that has off, and low -> high. I suppose I'll go grab the service manual and the multimeter and start testing things Link to comment Share on other sites More sharing options...
Guest Posted July 25, 2006 Share Posted July 25, 2006 Did this ever get sorted out? I noticed that David Silver Spares in the UK has these available. I'd be interested if they work. I'll get some pictures of them soon... I don't know about the european heated grips... these I went down to the dealer and ordered as a honda accessory.But it's a pair of grips, and a little box that mounts to the left handle bar with a knob that has off, and low -> high. I suppose I'll go grab the service manual and the multimeter and start testing things Link to comment Share on other sites More sharing options...
enzed_viffer Posted July 25, 2006 Share Posted July 25, 2006 Unless there was a bung connection, or the rheostat was Kaput, sounds a bit like the relay was connected wrongly. Maybe. More info. Link to comment Share on other sites More sharing options...
