Member Contributer ov3 Posted March 4, 2006 Member Contributer Share Posted March 4, 2006 Having never owned a gps, I'm interested in the Quest 2. Can u mark out a route in the GPS for the day? Would this have to been done on the pc then uploaded to the Quest 2? Much like highlighting a days ride on a map. Found my answer Route Planner lets you save 50 routes, specify via points, and preview turns Cheers, Link to comment Share on other sites More sharing options...
Member Contributer The Big Sur Posted March 10, 2006 Member Contributer Share Posted March 10, 2006 I have a silly question. Can anybody tell whether the RAM mount connected to the tank bolts might hinder a jastek powerlet steering head kit? cheers OK, as promised, pictures. As shown in the first pic, it is only slightly lower than the tach, so you don't have to look very far, combine that with audio driving directions and it is a minimal distraction.Also, the RAM mount is shown how it connects to the tank bolts. You simply do not use the steel loop that it supposed to go around a handle bar. Only problem with this setup is the tank bolts are a little short. I am trying to locate some slightly longer ones as they only have a couple of threads catching but it is secure just a PITA to lift the tank. border='0' alt='user posted image' /> border='0' alt='user posted image' /> <{POST_SNAPBACK}> Link to comment Share on other sites More sharing options...
Guest Posted March 10, 2006 Share Posted March 10, 2006 I have the tank Ram mount and from everything I can tell, I would think that it would. I put the power outlet on the left panel instead of the steering stem just for this reason. Perhaps if you got a 90 degree plug plugged into the steering stem you could get away with it. Link to comment Share on other sites More sharing options...
Member Contributer The Big Sur Posted March 11, 2006 Member Contributer Share Posted March 11, 2006 I have the tank Ram mount and from everything I can tell, I would think that it would. I put the power outlet on the left panel instead of the steering stem just for this reason. Perhaps if you got a 90 degree plug plugged into the steering stem you could get away with it. <{POST_SNAPBACK}> Unless one moves the mount backwards and closer to the tank? But how convenient would it be then to look at the gps's screen? Link to comment Share on other sites More sharing options...
Member Contributer jeremy556 Posted March 11, 2006 Member Contributer Share Posted March 11, 2006 Having never owned a gps, I'm interested in the Quest 2. Can u mark out a route in the GPS for the day? Would this have to been done on the pc then uploaded to the Quest 2?Much like highlighting a days ride on a map. Found my answer Route Planner lets you save 50 routes, specify via points, and preview turns Cheers, <{POST_SNAPBACK}> You could swing the arm back to clear the plug, but I probably wouldn't recommend the combination, because you will have to look further down to see the screen than you already do. If you only use the plug rarely it might work out OK. Link to comment Share on other sites More sharing options...
Member Contributer The Big Sur Posted March 12, 2006 Member Contributer Share Posted March 12, 2006 You could swing the arm back to clear the plug, but I probably wouldn't recommend the combination, because you will have to look further down to see the screen than you already do. If you only use the plug rarely it might work out OK. <{POST_SNAPBACK}> Thanks for the info. Actually I was thinking of plugging my radar detector in it. Maybe I should get one of these... <_< border='0' alt='user posted image' /> RIGHT ANGLE CIGAR CABLE.jpg border='0' alt='user posted image' /> DUAL CIGAR COIL CABLE.jpg Link to comment Share on other sites More sharing options...
Forum CEO HispanicSlammer Posted July 21, 2006 Forum CEO Share Posted July 21, 2006 I dropped mine out on the road dirbiking and cracked the case, then a month later the case broke even more. On my long trip to UTAH it stopped working, so I sent it into Garmin for repair - cost me nothing but shipping and I got it back today a brand new unit in perfect working order! Garmin Rocks!! Link to comment Share on other sites More sharing options...
Member Contributer jb72 Posted December 3, 2006 Member Contributer Share Posted December 3, 2006 Only problem with this setup is the tank bolts are a little short. I am trying to locate some slightly longer ones as they only have a couple of threads catching but it is secure just a PITA to lift the tank. I like this set up for my upcoming Quest II that Mrs. Clause is getting for me :D. If there is a better setup, I'm all ears. Since the stock tank bolts are a little short, has anyone found longer bolts.? Or should I even be worried? I'm counting down the days until I can try and get lost!! :blink: Thanks, Jeff Link to comment Share on other sites More sharing options...
Member Contributer jeremy556 Posted December 3, 2006 Member Contributer Share Posted December 3, 2006 I like this set up for my upcoming Quest II that Mrs. Clause is getting for me :D . If there is a better setup, I'm all ears. Since the stock tank bolts are a little short, has anyone found longer bolts.? Or should I even be worried? I'm counting down the days until I can try and get lost!! :blink: Thanks, Jeff cut a notch out of the ram mount for the lip of the gas tank (you'll see when you do it), and the trick i found, is to loosen the rear tank bolts, then start the front bolts and tighten them all down. Link to comment Share on other sites More sharing options...
Member Contributer jb72 Posted December 3, 2006 Member Contributer Share Posted December 3, 2006 cut a notch out of the ram mount for the lip of the gas tank (you'll see when you do it), and the trick i found, is to loosen the rear tank bolts, then start the front bolts and tighten them all down. Thanks for the quick response, I will give it I shot when when I'm off during Christmas. Can't wait to try out the GPS. Link to comment Share on other sites More sharing options...
Member Contributer dr.toto Posted December 3, 2006 Member Contributer Share Posted December 3, 2006 I put longer bolts in mine. It's real easy to strip aluminum threads. My local John Deere or Ace hardware has bolts. Link to comment Share on other sites More sharing options...
Member Contributer jeremy556 Posted December 3, 2006 Member Contributer Share Posted December 3, 2006 I put longer bolts in mine. It's real easy to strip aluminum threads. My local John Deere or Ace hardware has bolts. i have helicoils in both of my front tank mount bolt holes :joystick: Link to comment Share on other sites More sharing options...
Member Contributer jb72 Posted December 4, 2006 Member Contributer Share Posted December 4, 2006 i have helicoils in both of my front tank mount bolt holes :joystick: Is this due to stripped threads or a preventive measure? As the Dr. mentioned it may be easier to find longer bolts. If I were to locate bolts, I guess I get a bolt that is the distance of the mount plus the length of the stock bolt. Link to comment Share on other sites More sharing options...
tinyminds Posted December 4, 2006 Share Posted December 4, 2006 It keep several full states loaded at once all the time on mine. I currently have FL and GA. Before I Had KY, TN, Part of GA and Part of NC. Never had a problem keeping everything I needed loaded at once. I used the 5 1/2 inch Stem they have on GPSCity.com with the Trimount Plate. I had to have one that would sit up high enough when using my tank bag, but not look horrible when i'm not using my tankbag which is most of the time. Heres a couple pics of mine. No complains on Garmin Quest. Probably one of the best mod's I have on my bike, most useful atleast. Link to comment Share on other sites More sharing options...
Member Contributer jb72 Posted December 4, 2006 Member Contributer Share Posted December 4, 2006 I used the 5 1/2 inch Stem they have on GPSCity.com with the Trimount Plate. I had to have one that would sit up high enough when using my tank bag, but not look horrible when i'm not using my tankbag which is most of the time. Heres a couple pics of mine. No complains on Garmin Quest. Probably one of the best mod's I have on my bike, most useful atleast. By the looks of the picture and the name of the product that it goes into the triple clamp (remove cap). I tend to ride with my tank bag almost 100% of the time. I guess the tri mount is an option plate to buy if mounting more than one piece of electronics. What is like to see the guages and still be able to glance at the GPS without going off the road? This is my first GPS, and the fact of trying to do some touring...I do like that roady you have :thumbsup: I tried on GPSCity.com to locate the stem. Do you still have the part # ? Without going out to your bike to take a picture, do you have a straight on (rider perspective) shot? Thanks again, Jeff Link to comment Share on other sites More sharing options...
tinyminds Posted December 4, 2006 Share Posted December 4, 2006 By the looks of the picture and the name of the product that it goes into the triple clamp (remove cap). I tend to ride with my tank bag almost 100% of the time. I guess the tri mount is an option plate to buy if mounting more than one piece of electronics. What is like to see the guages and still be able to glance at the GPS without going off the road?This is my first GPS, and the fact of trying to do some touring...I do like that roady you have :thumbsup: I tried on GPSCity.com to locate the stem. Do you still have the part # ? Without going out to your bike to take a picture, do you have a straight on (rider perspective) shot? Thanks again, Jeff Heres the part numbers for everything I ordered from the GPSCity.com: 1 - RAM Mount Aluminum 5.25'' Long Arm with Double 1'' dia Socket (RAM-B-201U-C) 1 - RAM Mount Aluminum 1'' Ball 2.5'' dia Base Plate (RAM-B-202U) 1 - RAM Mount Zinc Coated 0.75'' to 1'' Round Rail U-Bolt Base with 1'' Ball Aluminum Plate (RAM-B-231ZU) 1 - RAM Mount Plastic Triple Cradle Plate Adapter Heres a pic from what I see from my perspective @ 6' 0" Tall. It works perfect for me, even with tank bag on which I put on for the pic since you said you use a tank bag most of the time. I have the Cortech 21-Liter tank bag. Let me know if you have anymore questions. Link to comment Share on other sites More sharing options...
Member Contributer jb72 Posted December 5, 2006 Member Contributer Share Posted December 5, 2006 Heres the part numbers for everything I ordered from the GPSCity.com: 1 - RAM Mount Aluminum 5.25'' Long Arm with Double 1'' dia Socket (RAM-B-201U-C) 1 - RAM Mount Aluminum 1'' Ball 2.5'' dia Base Plate (RAM-B-202U) 1 - RAM Mount Zinc Coated 0.75'' to 1'' Round Rail U-Bolt Base with 1'' Ball Aluminum Plate (RAM-B-231ZU) 1 - RAM Mount Plastic Triple Cradle Plate Adapter Heres a pic from what I see from my perspective @ 6' 0" Tall. It works perfect for me, even with tank bag on which I put on for the pic since you said you use a tank bag most of the time. I have the Cortech 21-Liter tank bag. Let me know if you have anymore questions. That helps A LOT :thumbsup: . Did you put in longer tank bolts? Link to comment Share on other sites More sharing options...
tinyminds Posted December 5, 2006 Share Posted December 5, 2006 That helps A LOT :thumbsup: . Did you put in longer tank bolts? No, I just used stock, but I probably should change them. I've had them out and back in probably 6 times since I've had this setup, no problems with threads so far. There's probably about 1/3 inch threads holding, it does the job as long as you don't overtighten. Link to comment Share on other sites More sharing options...
Member Contributer jb72 Posted December 5, 2006 Member Contributer Share Posted December 5, 2006 No, I just used stock, but I probably should change them. I've had them out and back in probably 6 times since I've had this setup, no problems with threads so far. There's probably about 1/3 inch threads holding, it does the job as long as you don't overtighten. I will definatley take care when tightening. It looks like this is the only way of mounting the Quest or similar. I may try the local hardware store for a little longer bolts but will wait and see when I put it on. Did you cut the the ball to fit the tank as Jeremy556? It seems that be a must as the fit seems very tight. Thanks, Jeff Link to comment Share on other sites More sharing options...
Member Contributer jeremy556 Posted December 5, 2006 Member Contributer Share Posted December 5, 2006 i just happen to have the ram mount off as my bike is disassembled, so i shot a picture of my 'modified' ram mount ball. not pretty but, it works. Link to comment Share on other sites More sharing options...
Member Contributer rbertalotto Posted December 5, 2006 Member Contributer Share Posted December 5, 2006 Speaking about "not pretty"...............That hand looks like a good OUCH! Hope it's getting better? Here is a mount I made for my "farkles". Very easy to fabricate out of square steel tubing. Cut, drill, file, spray paint and mount. All kinds of stuff can be attached to it. And being attached to the handlebars I've found is tjhe least vibration. Link to comment Share on other sites More sharing options...
tinyminds Posted December 5, 2006 Share Posted December 5, 2006 Did you cut the the ball to fit the tank as Jeremy556? It seems that be a must as the fit seems very tight.Thanks, Jeff No I left it alone. It doesn't touch, its just close. Link to comment Share on other sites More sharing options...
Member Contributer jb72 Posted December 5, 2006 Member Contributer Share Posted December 5, 2006 Thanks to everyone for sharing their pictures etc. This forum is very helpful :thumbsup: I think I am going to try the RAM mount and give it a shot. Now I just have to wait for Christmas. Link to comment Share on other sites More sharing options...
