VikingDave Posted March 7 Share Posted March 7 Hi All, My VFR750F-M has a funny temp reading, the gauge moves but barely, the bike is obviously getting up to temp, the fan kicks in but the reading is squint. I've done the temp sender grounding and the needle didn't move. Is it a faulty gauge even though it moves? Could the sender be gummed up? Anything else it could be? Cheers! Quote Link to comment Share on other sites More sharing options...
Member Contributer Captain 80s Posted March 7 Member Contributer Share Posted March 7 I think you can put some voltage to the meter and check for movement... 2 Quote Link to comment Share on other sites More sharing options...
Member Contributer Grum Posted March 7 Member Contributer Share Posted March 7 Things to check...... 1. Check for continuity of the Sensor Body (Ground) back to the Battery Negative Terminal. 2. Make sure the connector to the Sensor is clean and making good contact. 3. Measure 12v between the Sensor wire and Ground, ignition to On. Refer Service Manual. 4. Check continuity of the Sensor wire, from the Sensor up to the Instrument. 5. Check 12v at the Instrument Black/Brown 12v, Green/Black Ground. 6. Check the three connections at the instrument are good and clean. 7. Do the resistance checks for the Sensor. Refer Service Manual. The Service Manual is downloadable from this forum if you don't already have it. 1 Quote Link to comment Share on other sites More sharing options...
squirrelman Posted March 8 Share Posted March 8 if the coolant level falls too far below the temp sensor the reading will not be correct. best to check under the rad cap cuz overflow bottle level could be misleading 3 Quote Link to comment Share on other sites More sharing options...
VikingDave Posted March 8 Author Share Posted March 8 Thank you all so much! Will get onto these steps on the weekend! Quote Link to comment Share on other sites More sharing options...
